Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge Profile XL44 - Everything works except the Oven, it just stopped
Basically all functions of the range works fine (GRILL STOVE, etc), howver, the oven will not start any longer, it was fine yeterday..... ;-(
  • 32 more comments
  • Anonymous Dec 23, 2007
    OVEN MAKES A POP SOUND WHEN IT STARTS
  • Anonymous Dec 25, 2007
    Please describe the specifics of your problem below. We'll add
    your post as a comment to Matrix5's Ge Profile XL44 - Everything works except the Oven, it just stopped problem, and notify you when a new solution is offered.
  • Anonymous Dec 27, 2007
    It started taking longer and longer before it would go on. Today I haven't been able to get the oven to bake or convection bake at all.
  • marymellow Jan 02, 2008
    We have the same problem - really created stress through the holidays - extra hours to roast meats and pies and cookies were just a loss.
  • Anonymous Jan 03, 2008
    GE XL44.. Oven was working just fine . Then it would no longer work . Everything else works just fine. Could it be the electric ignition for the oven? How do I fix it? thank you. Coal
  • idbrn4u Jan 03, 2008
    Everything works with my GE spectra Oven range. Burners and broiler. But the oven wont start. The glow plug wont burn when the oven is turned on.What do I do? change out the glow plug? Or is it a short or computer problem sending the signal to the plug? Help!? TRhanks, Curt
  • Laura3 Feb 08, 2008
    Burners and broiler works...over won't heat up.
  • Anonymous Feb 10, 2008
  • Anonymous Feb 19, 2008
    top burners and broiler works fine, but the oven will not heat up. the ignitor will not glow..GE Profile Spectra XL44
  • Anonymous Feb 25, 2008
    the ignitor burned out so we replaced it and the oven will still not light or heat up. this stove is only seven years old, my last stove was 30 years old!
  • mendel0101 Feb 27, 2008
    Everything works except the Oven, it just stopped.
  • Anonymous Mar 01, 2008
    Oven does not work, all of a sudden. The Broiler works, and the gas stove top works. I made sure the red ignitor was in the up position after pulling out the warming drawer.
  • Gwen Jones Mar 01, 2008
    Ok, I'm having the same problem with a bit of a twist. I just used the self cleaning feature on the oven and now it will not work. It will clean again, heating up properly and all, the oven door opens after the cleaning cycle is complete as well, but if you turn it onto say 350 to "bake a cake" or whatever, it does not heat and the clean light flashes.
    Don't bother calling GE help desk, they only want to send out a repair tech.
    After explaining the issue to the help desk person repeatedly and being continually told it was probably my ignitor (which it can't be because it will clean and that in itself takes HEAT) I kindly thanked her for her help and let her know I'd be looking for a new oven this week (which excited her a lot and at which point she became very helpful); until I informed her I'd be looking at the Whirlpool website.
    This will be the last GE product I own, its less than 10 years old and if I'm going to make a major purchase, I'll invest in a more helpful/friendly/less money-grubbing organization.
  • Im_Me Apr 10, 2008
    My XL44 burned out its OEM ignitor last fall, no big deal right?
    bought a new one, generic, and the oven started to heat on a test run, but when I went to bake, we reached temp once, cycled off, and never cycled on again. The new ignitor also burned out! Any ideas?
  • Anonymous May 11, 2008
    i have the same problem how can i change the ignition need pics1
  • Anonymous May 12, 2008
    My GE XL44 Oven is taking a long time to go on, the oven and broiler
    will not ignite. The igniter is a yellow orange color but more toward
    the yellow color.
  • Maddsmith May 13, 2008
    The oven on my GE Profile XL44 gas range is not functioning properly, although the top burners and broiler work fine. It is now extremely slow to reach the requested bake temperature, because the oven burner does not burn steadily until reaching the requested temperature. Instead it burns only in 3 second bursts and then goes off for about 7 seconds. This problem has increased gradually over the last 2 months. At first, the oven would heat up OK, but then fail to maintain the requested temperature. Then it began to take longer and longer to heat and also then fail to maintain the requested temperature. Finally, yesterday, the oven would not reach above 200 degrees. I have tried adjusting the air adjustment shutter, with no effect. As I said earlier, the top burners and the broiler work fine. Ant thoughts on what else can I do or replace to correct this problem? Thank you. Doug
  • Anonymous Jul 08, 2008
    I have a GE Spectra XL 44 gas oven and range. I was preheating the oven to 375 and it took almost 1/2 hour just to get to 215. An hour later and it's still not at 375. I am able to cook on the stove top. We tried to turn it off, then on again, but that was obviously no help. It appears that the gas is on inside the oven. What may be the problem?
  • AliKat715 Jul 08, 2008
    I have a GE Spectra XL 44 gas oven and range. I was preheating the oven to 375 and it took almost 1/2 hour just to get to 215. An hour later and it's still not at 375. I am able to cook on the stove top. The oven appears to be working inside. What may be the problem?
  • hebru Jul 28, 2008
    Stove and broiler light. Oven burner does not light at all.
  • ssuiter Aug 04, 2008
    The burners on top work but the oven does not heat up.
  • Qnjjon Aug 14, 2008
    From Day One, it has taken my oven 40 min to reach 425 degrees. That's unacceptable. What can be done short of replacing the range?
    Nancy
  • Anonymous Aug 20, 2008
    I am having the same problem. stove works but oven just stopped
    working. will not light up at all.
  • spateras Sep 03, 2008
    Ge Profile XL44 - Everything works except the Oven, it just stopped problem. I tried to reset by turing off all electricity but it didn't work.
  • olivariano Sep 28, 2008
    have exactly the same problem (or nowadays, issue)
  • thomas czech Dec 11, 2008
    GE stove. Stove top works, but the oven does not, it gets luke warm but will not heat up properly. The broul light comes on but element does not get hot, the bake light will not turn on and the element does not heat up either.
    Frusturated!
    I checked the breakers they are fine and changed the ovens one fuse under the lid at the top where the knobs are.
    email me with solution pleae, I am at my wits end.
    I am also not electrically inclined
    thomasczech@gmail.com
  • d_lundin Dec 27, 2008
    ignition tubes will not com on replaced the bottom one still nothing what does it mean operating auto or manualy
  • leonard154 Dec 28, 2008
    Used the oven this morning and it was working fine. Wanted to bake something 1/2 hour later and it wouldn't ignite.
    Used the oven this morning and it worked just fine. Wanted to bake something 1/2 hour later and it would not ignite. Broiler and burners work fine. Help!
  • ovennowork Jan 04, 2009
    I too have the same problem and am oven challenged!!! My G.E. Gas oven works, except for baking? Help, I bought it off the floor and it is about 9 to 10 years old, I don't have the model number or where is it on the oven?
  • Anonymous Jan 05, 2009
    Top burners work, broiler works. Oven will not fire.
  • windsong114 Jan 19, 2009
    gas burners work, but oven takes 20 minutes for gas to light. temp only reaches about 100 degrees. what might the problem be? thanks in advance . WINDSONG114@live.com
  • wbandrh Feb 24, 2009
    is this an easy project?
  • gmoore1960 Mar 01, 2009
    Broiler and stovetop work, but oven won't ignite
Please give suggestions for the oven not working. the ignitor is working fine
Posted on Sep 13, 2008
I figured out what the Issue is with my oven. I took off the back panel, a wire which runs from the teperature control knob to what I think mught be the thermostat is burnt off. I cleaned the wire and temporarily twisted it back on and the oven works now. I will call a tech tomorrow to replace the wire and put the tester on it to make sure the thermostat works properly so the wire wont burn off again or catch the oven on fire.
Posted on Dec 11, 2008
Replace the oven ignitor.
Posted on Feb 23, 2009
  • 3 Answers
Check your igniter, if that is good than oven safety valve could be a problem, if igniter is lighting than it sends the hat to safety valve from that the valves opens up and gas pass through
Posted on Feb 10, 2008
Lockrd door flashes on and off cant use oven
Posted on Dec 26, 2007
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 25, 2011 | GE Ovens
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
heatman101
Mar 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
7,662 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
