Question about Kodak EasyShare V1073 Digital Camera
Camera not turning on properly
My camera was working fine until the battery went dead. it would not recharge so i bought a new one.Now it turns on.. beeps once then turns all black.. yet the power button says its still on.. What can i do to resolve this matter?
My batteries went dead and camera shut off. Now I
if the camera wont turn on remove the memory card and make sure your pictures are transfered. Try using regular disposable batteries. Also when trying to turn it on try holding down the power button for 5 seconds. If it still doesnt turn on coud be a broken switch connection.
May 14, 2010 | Canon PowerShot A540 Digital Camera
My camera worked perfectly fine until the battery went dead. it wasnt the original battery that came with the camera and i charged it with the charger that did come with the camera so i thought the charger...
your battery area is infected with the chemicakl that is leaked from your old battery.
get it cleaned by an expert with chemical treatment.
also fornat your emory after cleaning
sagar
Jul 29, 2009 | Kodak EASYSHARE M763 Digital Camera
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
Our cannon powershot g9 camera is 1 year old. It will not turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jun 27, 2009 | Canon Cameras
Can not turn on
The digital camera needs high capacity batteries. Lithium Ion. The best way out is NiMh rechargeable 2500ma or better.... Think this is the problem...
Jun 06, 2009 | Kodak Easyshare C813 Digital Camera
It dosent turn on
i have the same problem. i bought new rechargeable batteries and they went dead really fast and then i put some new batteries in and i took like 5 pics and then the battery indicator said the battery is low. i dont get it whats going on with this camera.
Jan 05, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Camera dont come on
The battery or the camera itself may be faulty, take the camera back if you bought it new
kind regards and please don't forget to rate us
Dec 08, 2008 | Jazz DV-179 Digital Camera
Battery fully charged but cannot use camera. Applied new batteries works in review mode only Fuji Fine Piix F420
My camera had a similar problem. It would work only in review mode and as soon as photo/film mode was selected it went dead. What I did was 'discharge' the battery totally and then fully recharged it. This can be done by going to Menu-Option-Setup-Discharge. After I had done this the camera stopped going dead but the battery still had a very poor lifespan. I bought a new battery and now the camera works as new. Hope this helps-Steve.
Aug 16, 2008 | Fuji Cameras
Lens Error Message
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Mar 31, 2008 | Nikon Coolpix 7600 Digital Camera
Screen works in playback mode but turns off in camera mode as if batteries are going dead.
For some reason, Fuji does not emphasize that if your batteries get low, this is what happens. You just need recharged batteries or new batteries. Be careful with rechargables--before recharging them when this happens, you first have to drain them using the discharge mode of your camera. Then they will take a complete charge. (Good for some 300 charges or so, I believe.) But if you don't discharge them first, they will take less and less of a charge, and last shorter and shorter. If you use regular batteries, they might not last for 50 pics before running out of juice.
Oct 27, 2007 | Fuji FinePix E550 Digital Camera
Kodak EasyShare V1073 Digital Camera Logo
85 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
