Question about Logitech Formula Force EX Wheel And Pedals Set
I got a problem. Every time i plug in peddals they emediatly brakes. No mater what i do they brakes. I unplug the peddals, and there's still braking...
    Problem Solver:
  • 5 Answers
Sounds like something is stuck in the switch
Posted on Oct 05, 2009
Replaced the master cyclinder for 2007 ford fussion reovee all the air fill the system with fluid but there still no pressur pushing the cluthc pedal back
The problem might be that your pressure plate for your clutch might be weak or your clutch slave cylinder might be leaking either or might need a shop
Jan 08, 2015 | 2007 Ford Fusion I4 SEL Sedan
No brake lights when brakes are applied
First check fuses, them, bulbs and finally, brake peddal switch (generally in back side of brake peddal).
Keep us updated.
Feb 01, 2011 | 2004 GMC Envoy
I have a 91 s10 2wd 5spd with a 2.5 4cyl... i bought the truck with the brakes not working, it had a bad rear brakeline that was cracked right in front of the rear driver tire. and since this truck is...
the master cyclinder is divided into diagonal wheels. meaning that each line from the master cyclinder provides fluid to a front wheel and rear wheel. on the front resevoir of the master cyclinder it would be perhaps the left front and right rear brake for example. you need to block the lines going to the rear wheels independently and then bleed the brakes again starting with the wheel furthest from the master cyclinder.
Dec 08, 2010 | 1991 Chevrolet S-10
Honda civic 96 slow to speed up.no mater if i press the peddal all the way down
might of jumped a couple notches out of time next timing belt checked
Oct 07, 2009 | 1996 Honda Civic
How to bleed brake lines for a 1990 oldsmobile cutlass ciera
Two people, one to pump the peddal and one to open and close the bleeder valve....
Person 1 pumps the peddal 5-6 times, then holds the peddal, while person 2 opens the valve till the peddal hits the floor, then person 2 closes the valve.
you start on the Passenger rear and do this till you get no air and only fluid, then repete process on Drivers rear, then Passenger front, the Drivers front...
Make sure valve is closed when pumping or realsing the peddal, as this will allow air into the system.
Check fluid level after each wheel to ensure you don't run empty during operation.
Sep 15, 2009 | 1990 Oldsmobile Cutlass Ciera
How do i bleed the brakes on my 1998 gmc jimmy
it takes two people to do, one to pump and hold the brake peddal and one to open the bleeders....
One person pumps the peddal 5-6 times and holds, while the other starts at the Passenger rear tirer and opens the bleeder valve till the brake peddal hits the floor, and close it, do this till no air comes out but only fluid, then go to Drivers Rear, then Passenger Front, then Drivers Front.....
DON'T open the vlave while they are pumping, or allow them to let up on the peddal till you have the vlave closed again, as that will put air back into the system.
If you have any other probs, or questions, email me at dswenk@live.com
Sep 14, 2009 | 1998 GMC Jimmy
Brake lights stay on even when car is off.
look up under feet area brake peddal has a switch hooked to brake peddal could be bad switch or something catching it! good place to start!
Feb 04, 2009 | 1997 Buick Skylark
Logitech Formula Force EX  Wheel And Pedals Set Logo
118 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
