Question about JVC Video Cameras
An error number e30 appears - JVC Video Cameras
  • 10,515 Answers
The "E30" error code is displayed when reading/writing data on a storage card has failed.
Especially, the error code "E30" may appears when you tried to remove a storage card while the camera was processing data.
Solution
To clear the "E30" error, try performing the following procedure.
1. Try using another storage card.
If you have another storage card, try loading it in the camera.
If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera.
2. Use your computer's ScanDisk utility to check the storage card for errors.
Use ScanDisk to check the storage card for card error or card failure.
Refer to the instruction manual for your operating system or Windows Help for further instructions.
(If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.)
Be sure to back up the data on the storage card on the computer before you check the CF card.
If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card.
Follow ScanDisk's on-screen instructions to solve the problem.
3. Format the storage card with your camera
Try to format the storage card with your camera.
Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a storage card will erase all data on the card.
Once the storage card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors.
If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the storage card.
If turning the camera off and then on again, and then performing steps 1 to 3 above fails to clear the error, a camera malfunction may have occurred.
Please contact the retail store where you purchased the camera or the nearest Canon service center.
If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded.
Precautions for handling a storage card:
- Do not remove a storage card or turn the camera off while the camera is recording, loading, or erasing data on a storage card.
- storage cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration.
- Do not attempt to disassemble or alter a storage card.
- Place the storage card in the supplied case for storage.
- Moving a storage card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the storage card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature.
If problem persists, send the unit for repair or contact local tech.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 05, 2009
Canon irc2100
Sir, there doesn't seem to be an error code accounted for that reads E30.
Canon IRC 2100 Service Repair Manual
That is the link to the service repair manual which also has the error codes so you can diagnose what is going on although there doesn't seem to be an E30 code accounted for.
This is a more extended list of all of the error codes and once again there seems to be no E30. There are 9 pages of error codes if you'd like to look.
Error Codes Canon iRC2100 page 1
Perhaps a mistype?
Aug 30, 2014 | Canon iR 2016i Black and White Copier
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Code e30 error
Hi John, thank you for your inquiry!
If you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, and based on the symptoms you are describing it could potentially mean a number of things: a pressure sensor issue, defective wiring, faulty pump, and valve assembly problem and/or control board issue. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Thank you for allowing me to assist you in a small way.
Sep 15, 2013 | Frigidaire ATF6000ES Front Load Washer
Electrolux washing machine error code e30
Hello sreenivasulu, if you are receiving error code E30, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
Jul 25, 2013 | Electrolux Washing Machines
Wat do;s Err-80 meen
Looked up on Canon.es and this is what I found.
FAQ: What does the error code 'Exx'?
FAQ ID: 44574
Last Modified: 22-Jan-09
Cause
Answer:
When an error occurs the camera will display an error code like "Exx", where "x" represent numbers.
See the list items at the bottom of this page when it shows following error codes.
"E18" error of the target unit / lens barrel
"E30" and "E50" error of the CF or SD card
When an error code "Exx" different from those already mentioned, the camera off and then turn to try to capture or play back images.
If this error persists or an error code appears often, there was a malfunction of the camera.
Note the error code and contact the retailer where you purchased the camera or the nearest service center for Canon.
I hope this helps
Jan 24, 2012 | Canon EOS-D30 35mm SLR Camera
Error e30 on mp198 printer
Error E30 are not related with resetting printer :D. Error E30 is caused the main board or board of the printer wet by ink or other liquid things that make some components of the board short. Maybe temporary short and also permanent short, it caused printer mall function. in my experience on the canon printer board is only temporary mall function till we clean the board. You can clean it with thinner or other liquid cleaner.
source : http://scmedan.com/2012/how-to-fix-error-e30-canon-printer.html
Jul 16, 2011 | Canon PIXMA MP190 All-In-One InkJet...
I purcahsed a new canon SLR 7D and have an error message on the LCD screen E30. instructions says to remove battery pack or turn off the camera but it seems its not working at all. i have tried so many...
According to Canon's Knowledge Base here, this error means that there is a problem with the shutter. It appears that the camera needs service. If you just purchased the camera, it should be covered by warranty.
Mar 26, 2010 | Canon Cameras
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Video Cameras Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
