My fan runs continuously, even in the off position. Sometimes the A/C is blowing too (if it gets above the set tempature), most of the time it's just the fan. How can make it stop. This is really adding on to my electricity bill.
  • 80 Answers
Is there an auto/on selector at the thermostat?
make sure its set to auto
if its set correct and still runs ...i would assume the thermostat might be the bad guy...i would open the thermostat cover and remove the "G" connection. the fan should stop running
Posted on Oct 05, 2009
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
My exhaust fans comes on sometimes and at other time they don't causing my radiator to run hot only when I cut the engine off
I believe that, u are meaning to learn why the electric cooling fans connected to the back of the radiator. Seem to turn on intermittently or not at all. Well, depending on the driving conditions, the region u live in, an the condition of the vehicle. The preventive maintenance schedule, the amount of devotion to which that schedule was followed. Is the key to most all Vehicle problems. I believe that ur pontiac has a V6-3.1liter 4sp AT. Front-wheel drive- The cooling system on ur vehicle requires it be serviced at 100,000miles Although I would'nt recommend that large of an interval between service. It is what the Manufacture determined was efficient enough. What GM did not replicate when testing that vehicle. Are those variable consequences of ACTUAL vehicle wear an tear. It is normal for the cooling fans to start up even after you turn the engine off an park. But the fans should kick in durning operation if the tempature of the engine raises above normal operating range. Which is 140F- 210F. another factor to consider. AC usage, I recommend that the cooling system be serviced,if u don't know the last time it was serviced. GM introduced a special coolant (red)necessary for that system to function properly. If the car continues to go hot the problem is electrical.
Apr 09, 2011 | 1999 Pontiac Grand Am GT
We have a White-Rodgers 1F80-51. The fan blows
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
May 31, 2010 | Heating & Cooling
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Fan runs for hours after car is off
Could be the tempature sensor that turns the fan on, or the fan relay may be sticking.
Oct 05, 2009 | 2001 Dodge Durango
With all controls off it blows hot air even on the coldest setting
try this relearn procedure.
turn key on engine not running
set controlls to: vent, tempature cold, fan on low
turn key off
disconnect battery
wait 30 seconds
reconnect battery
turn key on do not start engine
wait 90 seconds while system recalibrates
turn key off
now start the engine and recheck for a/c operation
if this dosent fix the tempature controll than you will need to replace the blend door motor
and it is behind the glove box, it is black and has one plug on it. if you have to replace it make sure
you go through the relearn procedure afterwards.
wesleyschacht@hotmail.com
Jun 14, 2009 | 1998 GMC Jimmy
2000 Elantra Overheating
First when vehicle is cold like in the morning check and make sure that the vehicle has enough coolant/ antifreeze in radiator and reservoir. If coolant is need use a 50/50 mixture of water and antifreeze. You will need some time to do this let car run at idle until the temp guage is in the middle NOT+ normal operating temperature. At this point if the thermostat should be in the open position. Let vehicle run and check to make sure that radiator fan comes on. This should come on when guage is about midway/half way. If temperature rises above half going to h/hot and fan doesn't come on, you either have a BAD FAN BAD FAN SWITCH BAD FAN RELAY OR BLOWN FAN SWITCH FUSE. You will need to check all of the following I will help if its needed. If fan comes on and doesn't go off and vehicle continues to get hot even with fan running. Feel radiator hoses and see if the lower radiator hose is cool/cold. If it is you have thermostat that stuck closed. Replace thermostat and fix problem. If all the above is good and vehicle continues to over heat. THE BAD NEW IS THAT YOU MAY HAVE A BLOWN HEAD GASKET /CRACKED HEAD /BROKEN WATER JACKET. Basically you will need a HEAD JOB at least a head gasket. ONe tell tail sign of this is oil looking like milkshake/chocolate milk-a creamish while residue in oil or antifreeze. Contact if you need hel0p. Good Luck and thanks for using FIX YA
Jan 10, 2009 | 2000 Hyundai Elantra
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
