Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell T8011r does not have anything on display - does not appear circuit breaker is thrown - could it be wire disconnected at the plate or is there a fuse inside the unit?
  • 80 Answers
Check to see if you have power at the furnace. You thermostat is powered by 24vac coming from the furnace. You should have power on the "R" terminal.
Posted on Oct 07, 2009
    Problem Solver:
  • 14 Answers
I do not have the same thermostat but did need to turn my display off when sleeping downstairs near the thermostat. So, I called my utility company that installed the Honeywell Utility Pro Series Thermostat and here is how to do it. It was not in the Honeywell User Manual located at:
http://www.bgesmartenergy.com/media/pr/thermostat-operation-manual.pdf
  1. Press System – it will blink
  2. Press & Hold Square 3 + 5 at the same time
  3. 120 change with up arrow to 280
  4. 0 = OFF and 1 = ON
  5. Hit Done button
Too, Mine has a battery inside to backup the settings.
That is it for mine! Hope this helps.
Posted on Nov 20, 2009
What do I do My Honeywell thermostat T8411R is not working. Its display is dark
The thermostat wire may have and break and not getting power. Honeywell Customer Assistance at 1-800-468-1502
May 08, 2014 | Heating & Cooling
I have Honeywell T8011R programmable Thermostat. Turn AC on last night for first time...working fine...came back late morning to find display and fan off. Check circuit breaker...on. I took it off and...
Hello, first you must verify if you are getting 24 volts to the tstat at the secondary side of the transformer, if not you have a bad transformer. If you are getting 24 volts then check the batteries in the thermostat.
Apr 12, 2011 | Honeywell Programmable Thermostat Heater
My power windows will not work in my 1999 chevy venture someone told me to check the fuses i need a fuse box diagram please
Hi, there is no fuse, but there is a 30 amp circuit breaker in the instrument panel fuse box. I don't have a diagram, but there are only a couple of circuit breakers there. The breakers are supposed to be automatic. If the circuit breaker is thrown, you probably have a short. Use a 12 volt test light on both sides of the breaker to see if it's thrown. If both sides are hot, the breaker is still closed, and the problem is a broken wire or switch. If the breaker is open, you have a short in the switch or a grounded power wire. Either way, this will require troubleshooting. If you have a multimeter and would like to try troubleshooting yourself, I can provide some steps. Just let me know, and thanks for using FixYa.
Jan 26, 2011 | Chevrolet Venture Cars & Trucks
T8011r thermostat doesnt have a display, fuse is not blown out and it suddenly stopped working
Here is a link for the owner's manual. It gives several suggestions for the cause of the display being blank. Check those and let me know if that helps.
http://www51.honeywell.com/pacific/common/documents/T8000C_T8001C_T8011.pdf
Jun 06, 2010 | Honeywell Programmable Thermostat Heater
After a power outage my T8011R display will not come on. Breaker is on and the auto fan works--so there is electricity to the thermostat. Is it fried or is there a reset or fuse that I need to address?
Hi, if the stat is working and running the fan, what has happened is the circuitry is faulty that shows the digital display. Before we are certain this has happened, check to see if the stat has batteries in it. Pull the front cover off and check. If it does, replace them and see if the display returns. If it does great! If not its the circuitry in the stat and will need to be replaced. Keep me posted.
Shastalaker7
Jan 17, 2010 | Honeywell Electronic Programmable...
Honeywell t8000c display is blank, unit doesnt run
I would say that you have one of two issues. Either your thermostat is bad or you do not have 24v coming from the heating unit. In this case the problem would be in the low voltage circuit of the heater. At the heater you should have 24v AC when you place an electric meter across the R terminal and the C or W terminal. If you have no vaoltage across the R to either the C or W then you have a bad transformer or a blown fuse in the furnace. If you do have voltage ther and also at the t-stat then the t-stat has gone bad, replace it.
Nov 14, 2009 | Honeywell Electronic Programmable...
Two days ago my LG dishwasher model lDF 7810BB worked fine. Yesterday I loaded it and the display panel will not light nor show any sign of power. I check the circuit breaker several times and all other...
Check for voltage with a multimeter at the wires very near the front, just behind the kick plate. Follow the incoming electrical wire in and remove the little plate the covers the wires/wire nuts. I have seen wires that appear to be connected properly but the circuit is open.
Or, even though the circuit breaker is not switched open, the circuit itself, supplied to the front of the dishwasher is not live/hot.
Good Luck!
Mar 08, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
My Honeywell Thermostat Mdel # T8011R displays all the icons at the same time. This occured when returning from an electrical outatge.
After being disconnected from the expert, whom wasn't of any help, I called our AC/Heater maint. person for service. Upon hearing the problem he told me to turn the power source off for at least 30 minutes. After restoring the power source everything worked fine. The secrret is leaving the source off for at least 30 minutes. Your expert advised to turn the source Off and then back On which didn't solve anything. This remedy may work with other Honeywell models as well.
In all due respect, I hope I'm not charged for the lack of results which your expert provided.
Frank Mooney
Jan 27, 2009 | Honeywell Programmable Heat Pump...
Honeywell T8011R
Check for either an in-line fuse in the heating unit or a fuse on the control board also in the heating unit.
Nov 06, 2008 | Honeywell Programmable Thermostat Heater
Honeywell T8001C
Hi, take a look on amazon for replacement, here: Defy Mother Nature with our Best Buy. I hope this was helpful. Cheers
Apr 04, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
562 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
