Question about Dryers
Vent hose is too short
I have recently purchased a new home. While setting up my whirlpool dryer, I discovered that it is farther than 8ft from the outside vent. the "standard" vent hose is only 8ft and will not reach. Is it okay to connect (2) vent hoses together? Are there any other options available? Please Advise as soon as possible. scott.runge@nationalcity.com
Thanks
  • Dryers Master
  • 7,482 Answers
Yes, you can connect two vent hoses together, but only use as much hose as you need.
Cut the second hose to what ever length you need to get to the vent so that there is not too much unused hose in the vent system.
Every now and then remove the two hoses and check for lint build-up.
In a longer hose it will build more rapidly than in a short hose system
Good luck,
I hope this helps
Posted on Oct 05, 2009
    President:
  • 1,653 Answers
Yes you can connect 2 together, obtain 1 longer hose or use a fixed rigid pipe suitable for hot water etc - similar to drain pipe. All these shouled be readily available from your local plumbing supplies store.
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
My whirlpool dryer lgr6620pqo doesnt dry clothes enough already replaced cycling thermostsat seemed to work now still not drying enough
Clean/Replace your dryer vent hose; also, make sure it is as taunt and short as possible. Any extra loops or turns prevents proper air flow (moisture) from leaving the dryer and being vented outside.
Also, check your outside dryer vent; sometimes critters make a home in the warm vent.
Hope this helps...
Jan 07, 2012 | Whirlpool Dryers
I have recently got second hand WHIRLPOOL LER4634JQ0 ELECTRIC DRYER, however haven't got power cable and Hose pipe. Can you please guide me which powercable and hose pipe to take ? where I can find...
look at the outlet that you'll be plugging it into,if it has three openings get a three prong cord if it has four holes in it then you need to buy a four prong cord,you can buy vent line at any store,if there's a home depot near you go there and get everything you need.good luck with your new machine.
May 15, 2011 | Whirlpool LER4634J Electric Dryer
I recently purchased a Danby Premiere 13000 btu portable air conditioner. I live in a condo with swing out windows. What are my options for venting (short of returning the unit for a refund or replacing...
John, unfortunately, you don't have many options, short of putting a hole in an exterior wall and putting an exhaust pipe with a cap (like a dryer vent has) and connecting the exhaust hose to it. OR if you have a clothes dryer in your condo and it's vented to the outside. You could temporarily disconnect the dryer's vent hose and connect the A/C's vent hose to the the dryer's outside vent.
Either way, it may be to much of a hassle . But, I'll let you decide that. I guess it will all depend on how hot your condo gets without A/C.
Let me know how it works out for you. Thanks.
May 05, 2011 | Danby Heating & Cooling
Please help...i have a brand new whirlpool dryer mod #wed9450wwh and it takes forever to dry a load of clothes...a small load or a large load. i have tried every setting and bought a new dryer...
Check the vent cap on the outside of your home to see what the air flow is like when the machine is on. It should be forceful enough to blow your haire back if you were to put your face in front of it. Make sure the vent hose behind the dryer is as short as possible and is not pinched or coiled. This definitely sounds like an air flow issue.
Kelly
Mar 21, 2011 | Whirlpool GEW9250 Electric Dryer
What does an AF code mean
you need to clean your dryer vents, must move machine back from wall and remove hose and clean out, you may have to call a vent cleaner, if you have to go farther out in the line..
Dec 19, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Water remains in flexible vent
check your vent exiting the home, your venting is not exiting properly
Dec 07, 2009 | Whirlpool GEW9250 Electric Dryer
I have attached to a plastic garbage can, the hose keeps popping out of the cover would you recommend that I secure with a dryer vent clamp? or other suggestions?
dryer vent clamp should work o.k.. make sure the garbage can is vented so air can escape. cut a @ 4" hole in the can near the top (or in the lid) and use silicone to cover the hole from the inside with household window type screen
Nov 14, 2009 | Toro Universal Leaf Collector with 8ft...
Whirlpool gew9200lw1, dryer does not heat everything checks out ok, replaced electronic control worked for a day then stopped working please help. The sensor and wire harness reads a short and no...
if limit switch has no continuity than it is bad,the heater will not come on.before you change the switch you nead to make sure that you do not have a blockage in your vent hose,make sure vent hose is clear from dryer to outside vent.a blockage in the vent hose will cause the high limit switch to go bad.
Jul 03, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Dryers Logo
Top Dryers Experts
