Question about Kenmore 73952 Gas Dryer
Kenmore dryer 70942 disassembly
I need to remove the front access panel so I can get to the lent compartment to clean it out.
thanks
  • xandog Dec 22, 2007
    there is a quarter in the lint compartment. How to remove it?
Get to the coil
Posted on Sep 13, 2008
    Genius:
  • 1,003 Answers
PULL UPWARD ON TOP COVER IT JUST SNAPS DOWN SIMULAR TO CAR HOOD
Posted on Jan 18, 2008
How do you open up the kenmore dryer model 80311900 with the front control panel for cleaning out lint
To disassemble the machine, disconnect the power!
I believe that model has two screws in the rear edge of the top panel. Remove the screws and slide the top panel to the rear and remove it. Then remove two screws, from inside the machine, that hold the front panel in place from the back. Label the wires, then disconnect them. Tilt the front panel forward, then lift the bottom of the front panel up.
Mar 05, 2017 | Kenmore Dryers
How to remove front panel?
How to Disassemble Whirlpool/Kenmore Dryer - YouTube
? 7:36
www.youtube.com/watch?v=O0R6XudHV7s
Aug 23, 2012 - Uploaded by AppliancePartsPros Follow these simple step-by-step instructions to remove the cabinet and rear panel, and get access to or ...
Sep 17, 2015 | Dryers
How to get Tooth brush from inside in the lent clean out
Get a 2' peice of plastic tubing 1/2" in diameter, and hold it on one end by a running vacuum hose.Stick other end lint cleanout area.
Depends on your model, but some units have a front kicker panel that removes and you can disassemble the lint basin.
Jan 22, 2014 | Dryers
How to remove the front panel
on bottom there is two screws remove them
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Nov 20, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
Cleaning lent from filter to rear exast port. Are their disassembly instuctions to access where lent has collected ?
The only place lint will collect is right now by the blower wheel, there should be 2 screws that go up and into the lid on the top of the door opening, take those long screws out take the top off and there are 2 more screws facing towards the front of the dryer on the top 2 corners of the front those are phillips also, take those out and the entire front panel assembly will pop off, there will be a couple wires attached at the bottom for the door switch assembly, and the drum also rides on this front so it will be laying on the front, and there are 2 hinge like hooks at the bottom that the front panel sits on you will have to lift it up before the bottom will come off. If you need further assistance, let me know.
Sean
Mar 27, 2011 | GE Dryers
I have a Kenmore 90 series dryer. I want to clean the lent that has accumulated. I want to remove the lower front panel to do this. How do I remove that panel
Get a putty knife or flathead screwdriver. There are two clips between the top panel and bottom panel about 3 inches from the corner. Push your screwdriver/putty knife straight in and it will release from the top. Give a little pull. There you go!
Aug 19, 2010 | Kenmore Dryers
How do I take the front lower panel off the dryer?
There should be retaining clips along the upper seam of the panel where it meets the front panel, about 2 inches in from each side. Take a putty knife and insert to depress the clip, while pulling out on the panel at the same time. Release the opposite side in the same manner. The panel will open from the top and be removed.
You mentioned poor heating and longer dry times. The following link will give you some good advice on how to resolve this issue:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Most dryer heat related problems are caused by poorly installed vent ducting, kinked, vent hoses, or clogs. You are right to suspect your dryer may need a good cleaning, but make sure you thoroughly inspect the vent ducting as well, though. If there are large accumulations of lint inside your dryer, there is a clog somewhere. If you have any questions, please let me know. I hope this helps you.
Apr 30, 2009 | Kenmore Dryers
Kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 08, 2009 | Dryers
Wont start How do i access the thermal fuse?
HI if theres a bottom panel on you dryer. remove front panel. their is where the thermal fuse is located on the air duct. if you dont have a bottom panel. pull the dryer from wall. remove back panel. clean all dust in dryer and the venting. the thermal fuse is on the left, on the air duct. a small plastic piece, with 2 blue wires to it. replace this part. thanks the appliance doc.please rate my answer. thanks.
Sep 03, 2008 | Kenmore 659 Electric Dryer
Kenmore Heavy Duty 60 Series Soft Heat Large Capacity Dryer
i need to take the bottom lent door off. I have replaced the board and it still say's says to clean the lent door. i have with the one in the dryer, but need to clean the bootm .
Feb 23, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
621 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
