Question about Brother HL-5240 Laser Printer
Getting a lot of paper jams even after putting paper (Hammermill) claiming to be 99.99% jam-free
Soulvisitor
  • 1113 Answers
SOURCE: Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Posted on Dec 28, 2007
SOURCE: Paper jam Brother MFC-215C
Thanks, your suggestion led me to the solution, the jam not in the rollers or a senser, but it's in the dock of the printer head, when the printer head moved across, I shone a torch into the dock and saw a black thing, so eventually pulled it and realised that it was paper and it had been dyed black by the ink so that's wht it would be hard to spot!!!! Thanks again
Posted on Apr 29, 2008
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_015.html?reg=us&c=us&lang=en&prod=hl2140_all
Posted on Mar 18, 2009
SOURCE: Paper Jam lite is on ( no paper jam )
did you try turning it off and then back on?
Posted on May 27, 2009
Paper feeder pulls multiple sheets of paper
PULL ALL PAPER OUT OF MACHINE EVEN THE SUPPLY, UNPLUG OR TURN OFF THE POWER TO THE UNIT, PUT A STACK OF PAPER IN THE SUPPLY TRAY & GENTLY PUSH FORWARD NOT FORCING IT UNTIL IT STOPS. TURN POWER BACK ON & TRY AGAIN. YOU MAY HAVE TO REPEAT THIS 2-4 TIMES BUT IT WORKED FOR MY HP DESKJET F4180 ALL IN ONE.
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
I have a paper jam in my OfficeMax paper shredder. How can I fix this problem?
Usually for a jam you just need to reverse it. If it is really jammed you may have a staple caught in there or too many sheets of paper. If you unplug it and then see if you can pull out the jam. If it is a staple you may need to use needle nose pliers to get enough of a grip to get it out. If this has seen heavy use and lots of multiple pages then you could have burned out the motor. These are not much more complicated that scissors so there isn't much to do to fix them. Most don't like staples or more than 2-3 pages max at a time (if that many) even if they claim more than that.
Sep 08, 2011 | OfficeMax Office Equipment & Supplies
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
I keep getting paper jams. Even if I put one sheet of paper in at a time, the paper keeps jamming and won't print.
Hi
I live in the mid west - during our significantly humid days my 926 wouldn't pull in any paper. I tried a lot of home grown techniques but none worked. I finally raised the air temp in my office which tended to dry out the paper and that worked. Of course your problem could be a broken gear or a worn out feed tire - also something stuck in the printer.
Aug 12, 2010 | Dell 926 All-In-One InkJet Printer
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Ongoing jamming/misfeed problems
feed rola in adf u have to change to roles from c350
part nr
4582-3047-01
May 18, 2009 | Konica Minolta Office Equipment & Supplies
Prints a couple of pages - then jams
Well, for now it seems to be fixed - I opened up the paper tray and there is a little part that grabs the paper on the front of the tray - kinda sticky - I just took a paper cutter and put a couple of scratches on it and it is grabbing the paper for now. I do have some of those to use for replacements - but I had just changed it about a month ago and don't think it needed to be changed out again - they usually last quite a while. So, we'll see how long this lasts. We do a lot of printing on this thing and it has been a great printer - maybe we are just wearing it out!
May 20, 2008 | Ricoh CL4000DN Laser Printer
DCP-7020
My suggestion is to take the printer to the highest floor in your building open a window and see if it can fly. or just use it as a $200 paper weight because after 3 months it has been to the shop 3 times and still is not working they way it should. Bad equipment bad support, and just plain bad product all around.
Mar 04, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother HL-5240 Laser Printer Logo
26 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
