I just tried to connect my new linksys router to my desktop and it slows to a crawl, without the router the high speed cable works fine, I am trying to connect my desktop, and then my wireless loptop which has not even been made part of the network yet! I want to get the connected desktop working first? Thanks!!
  • acetum
    acetum May 11, 2010
    Are you using a cable or trying to connect with a wireless card on your PC?
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 05, 2009
The wireless network is very slow compared to when I connect to one of the RJ45 ports in the back of the router. Every wireless connection I try crawls in speed. I have Wireless -G USB adapter in one...
Makesure your computer is not too far away from your wireless router andyou have a good signal. By placing your mouse pointer over the wirelessconnection icon, located in the bottom right corner of your taskbar, you cancheck to see if your signal strength is good. Anything less than a good signalcan cause intermittent connections.
SOLUTION:You will need to relocate your wireless router closer to your computer.
Dec 16, 2009 | Linksys WRT160N Wireless Router
Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Ethernet speed changes from normal to zero
If you have high speed internet go to your ISP webpage and do a speed test. If You are paying for say like 10 MEGS and are only pulling 1.2 Megs. It probably is your modem. Your speed will slow down to approx 7.5 behind a router. Also Your ethernet cable might need replacing. might also might try resetting your router. disconnect all power even the cable comming in and reset everything. Hope that helps.
May 24, 2009 | Apple eMac G4 Desktop
Loss of internet connection to desktop with WRT 160 N
If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
1. connect to modem with an ethernet cable, without the router
2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
Jan 20, 2009 | Linksys WRT160N Wireless Router
How can i connect notebook and desktop wireless
192.168.1.1 then enter the password, and your up, let me know...
Bobby
Nov 11, 2008 | Linksys Wireless-G WRT54GS Router...
I cant seem to install it
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings. access the router setup page and set the router to to PPPoe and enter your complete ISP username(email address format) and password. save settings and click the connect button on the status tab
Step 7: test the Internet connection once the status said connected
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 18, 2008 | Linksys Wireless N Gigabit Router
Speeding up internet
Here are a few suggestions on how to speed connection:
- Move router or pc location if possible. Closer = better connection usually
- Try changing the channel your router is broadcasting on. Sometimes there are slower channels and faster channels in heavy traffic area
- If you have any toolbars in your browser (i.e., yahoo or google), remove them. Those toolbars use up resources that can slow you down.
- Delete cookies and internet files
If these don't work, post a comment on here with your operating systems on laptop and desktop and router type.
May 14, 2008 | E-Machines eMachines Desktop PC
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
