Question about Toro Lawn Mower With Toro Power Tools
How to intstall toro recoil starter assembly - Toro Lawn Mower With Toro Power Tools
3 Suggested Answers
boscia
  • 163 Answers
SOURCE: Toro Mower Recoil Assembly
try turning it clockwise. if it doesnt work it means the inner coil may be broken. its pretty difficult to fix those but if you would to try let me know and i'll talk you through it
Posted on Nov 30, 2008
SOURCE: Broken recoil starter rope on John Deere 5E
No, there isn't.
You have to take it apart, and make sure the spring doesn't get loose, or you'll have to rewind it. There's probably enough to just re-knot it if you're real lucky. Would it be for sale?
Posted on Oct 20, 2010
How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
  • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
  • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
  • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
  • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
  • Once you are satisfied that the recoil is working properly re-install the remaining covers.
Jan 15, 2015 | Toro Garden
HOW TO FIX MY TORO RECOIL
You need to probably replace or put the recoil spring back in place.,You have to take the recoil off to do it.
Jun 22, 2014 | Toro Power Lawn Mower
Recoil starter
Go to you tube On the line repair recoil core
Feb 14, 2014 | Toro Power Clear 418 ZR - Single Stage...
Toro 6.5 recoil handle cord loose
yes you will need to remove the top cover to replace the starter cord
Apr 22, 2012 | Toro Garden
Toro personal pace lawnmower recoil spring broke
Go to www.youtube.com and type in fix starter spring lawnmower in Goggle.
Feb 28, 2012 | Toro Power Lawn Mower
How to put together a toro recoil
first you put the rope into place then place the spring in the center lock ,if its out then you tighten up the spring by turning it in the direction that will pull rope back in once at the end of recoil send rope into pull hole, hold it tight and let it coil up slowly,reattach to machine and your done.
Jan 14, 2010 | 2005 Suzuki RM-Z 450
Pull start on my Toro snowthrower (snow master 20 - model #38020) it wont recoil itself. I removed the starter housing but can not figure out how to get the pulley and starter recoil spring out/off of the...
Its basically the same....best bet is to just buy the new pull start mechanism...they are pretty cheap, and they go bad on those units all the time.
Jan 12, 2010 | Toro Garden
Doesn,t engage with engine
sounds like the dogs and or springs are worn.When you had the cover off the machine did you check that the dogs would freely move out when the rope was pulled? They some times stick and will not engage.
Dec 26, 2009 | Toro Garden
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Sep 20, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
554 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
