Question about Philips Televison & Video
Chirps when powered up - Philips Televison & Video
I have a 42 in magnavox lcd tv and it wont turn on at all and is also making a chirping sound coming from the back left of the tv. Picture just went out and gave a bad smell.
Posted on Aug 17, 2010
  • Philips Master
  • 19,396 Answers
IF TV is a CRT, the high pitched sound is caused by a faulty power supply unit, or a faulty deflection circuit.
If TV is an LCD, the chirping sound is often caused by a blown electrolytic capacitor melting and leaking internal fluid. This happens often with PSU capacitors.
Whenever this happens, do not try turning on the TV, or you can cause more damage to the set.
The TV must be disassembled and tested , starting from power supply board. Often it is possible to spot the leaking capacitor at a glance, it will be burnt, bulged, and leaks are often visible. The repair must be done by a technician.
Call the support number printed on your owner manual, or locate a local repairman.
Posted on Oct 05, 2009
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
CHIRPING SAMSUNG PROJECTION TV
Chirping is set is in shutdown---most likely in High voltage area of set.
Jun 11, 2012 | Samsung Televison & Video
RCA p46732ba projection TV no power.
This is a common problem and the set is in shutdown mode. It attempts to fire up three or four times (the chirp you hear) if it detects a fault it shuts down - the most likely cause is the HV (high voltage) block- caution working on it since HV is present - The repair generraly costs $200-400 P# 205064
Google your model # and HV block to see what I mean.
Oct 06, 2009 | Televison & Video
Hitachi rear projection tv wont power on makes a chirp
You could have a bad HV Transformer causing it to shut down.
Jun 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My 60" Phillips HDTV Model # 60pp9202/17f chirps, no pic or sound.
This is a common problem with the Philips Tv sets. Get a repair kit from www.TvRepairKits.com.
Jan 11, 2008 | Philips 60PP9202 60" Rear Projection...
Zenith iqc50h95 50 in rear proj
Rainman, can`t really be of any great help on this one, both techs can be right, the chirp is exactly as you thought, the set is trying to come on but there is a short in the set and it`s shutting down because of the short, could be convergence, low voltage power supply, high voltage power supply, until a tech gets in there and starts un-loading circuits it`s impossible to say where the short is, gonna have to call someone out for this one, good luck with it, BMW Rider
Jan 09, 2008 | Zenith IQC50H95W 50" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
Tv went dead while viewing, will not power back up
You have a short somewhere in the load for the power supply. Probably the horizontal output transistor and the flyback transformer. You need to have it checked out by a tech. You may want to get an estimate. Stargazer
Mar 11, 2007 | RCA F36715 36" TV
Televison & Video Logo
799 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
