Question about Acer X193W LCD Monitor
The resolution comes and goes...
I have the acer X193W and my laptop sundenly loose the resolution... This monitor is perfect for 1400x900 and some times this is available on the resolution list and some times is not... is really weird.. (well not that weird coming from windows, actually...) how can I solve that??? :S
  • 4,281 Answers
For that when you power up the computer press F8 key then enter in safe mode.
Then uninstall graphic driver then start it in normal mode then install graphic driver again then it wroks fine.
Let me know if you need more assistance.
Thanks.
Posted on Oct 05, 2009
Acer X193W Monitor comes on correctly, but after about 3 seconds it goes black. Can turn off & back on & get the same result.
the problem is not with your monitor the problem with your cpu which is not providing the signal that's why it goes off
Mar 04, 2013 | Acer X193W LCD Monitor
My Acer X193w. My monitor comes on and says cable not connected but when I connect the VGA cable the screen goes black even though it is still on.
VGA is an analog connection, so you should connect it to your monitor BEFORE starting up the PC. Otherwise it won't show anything
May 04, 2011 | Acer X193W LCD Monitor
Input not supported error
The native resolution for the x193w monitor is 1440x900. The monitor will only allow certain resolutions. You may need to create a custom resolution using the nvidia control panel.
Goto:
advanced options display change resolution customize create custom resolution horizontal pixels : 1440 vertical lines 900 refresh I belive is either 75 or 60. Whichever looks better scan type: progressive
Feb 22, 2011 | Acer X193W LCD Monitor
I go to screen resolution but the thing is the resolution is greyed out. please help Acer X193w
You need to install the latest drivers for your graphics card, so your computer can run at a higher resolution.
Nvidia Graphics Driver for Nvidia made Graphics Card.
AMD Graphics Driver for AMD Radeon made Graphics Card.
Select your Graphics Card model and Operating System.
Download and install.
Note: Only use the drivers provided for your make and model of graphics card!!!
Thanking you
damnor01
Feb 02, 2011 | Acer X193W LCD Monitor
What is the recomended resolution display setting for my Acer X193w monitor
A computer monitor is made of pixels (short for "picture element").
Monitor resolution is measured in pixels, width by height. 640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, an aspect ratio of 4:3. With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), all aspect ratios are the same.
Hope this initial information helps. Let me hear from you again for any clarifications.
Thank you for using fixya.com
Feb 23, 2010 | Acer X193W LCD Monitor
What should my screen resolution be
The maximum resolution for the Acer X193W LCD Monitor is 1440 x 90, which is a really good resolution range. It will depend also on what kind of graphics/video card and motherboard your computer has which can help determine if you can use the Acer at that maximum resolution.
Jan 26, 2010 | Acer X193W LCD Monitor
19" monitor problem
Try 1440x900.
Some LCDs don't like going off their supported resolutions.
Dec 09, 2009 | Acer X173WB Monitor
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Jul 14, 2009 | Acer X193W LCD Monitor
Rapid shuddering of icons, pix on Acer X193W monitor (10 mo. old)
in very first you have to check the pc with another display monitor
if display problem still available check the graphic card and video driver. remove the driver and reboot. check display resolution and refresh rate
Apr 12, 2017 | Acer X193W LCD Monitor
Acer x193w on win xp woulnt go above 800x600 resolution
The resolution issue you are describing sounds like a video card driver issue. You must determine what video card or chipset you have and apply the appropriate driver. The Acer x193w monitor is plug and play, it will display whatever the OS sends to it provided it is within it display range and 1440x900 is definitely within that range.
Dec 16, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
167 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
