Question about Canon PIXMA iP4600 Color InkJet Photo Printer
How can fix error 6A80 mp540 - Canon PIXMA iP4600 Color InkJet Photo Printer
Hi. I have a Canon MP540 printer. It was working fine until I moved it around a few minutes ago. Now it shows error 6A80 that isn't changing even when I switch the printer off and on again. Any tips on how...
Switch off the printer.Please disconnect the printer from the computer. Clean the printer inside with compressed air if you can otherwise open the printer cover and see there is no dirt/grit/paper stuck up. Replace the cove and the reconnect to the computer and switch it on. If it still shows the error then I am afraid you have to show it to a technician as some component has been displaced when it was moved.
Jan 06, 2011 | Cannon Office Equipment & Supplies
How can I fix error No. 6A80 on my Canon Pixma iP4700
Hi, That error may cause of a paper jam, check your printer if there is blockage and then remove those blockage if no blockage, and the error still appear try to reset your printer.
To reset follow this:
1. Turn off the printer.
2. Pressed simultaneously for 10 seconds on the following buttons:
3. Release the button "On / Off".
4. After a few seconds release the other buttons.
Thank you for using FixYa
Nov 15, 2010 | Canon iP4700 InkJet Photo Printer
B200 error Canon Mp540
B200 is print head overheating error. Find details here:
Canon E200
Jul 09, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Canon PIXMA iP4600 - error 6A80
Hello someone else here had this problem, this is what he posted: "Same problem with a Canon MP540 fresh from the box. Turned out to be the print head unit was not returning fully to the home position ie extreme right. My Fix : When the scanning unit cover is raised the print head unit moves left for access, look in the vacated area to the right, in particular the small black sponge where the head normally parks. I found a small spring jammed in beside the sponge, removed it and all is well. Don't know what the spring was meant to do but everything is working fine without it.On the MP540 the head unit now glows red, presumably meaning all is well... "
Jun 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon, Pixma MP520 and an error message is coming up 6A80 Printer error has accurred. Turn off power then back on again. If problems persist, see the manual. I can't seem to fix it, can you help
Put the colors out of the printer and do it on and off a few times and put the colors back in and a few times on and off again, that was working on my 6a80 problem.
Greetings Pieter.
Oct 19, 2008 | Office Equipment & Supplies
Error 6a80
Error 6A80
I had this error and a Canon engineer showed me how to deal with this.
Basically there is an "App Sensor" which is reporting the issue in my case the problem was with the "Purge unit".
(a) Left up the cover to reveal the ink cartridges
(b) Move the ink / print head to the left hand side
(c) Look to the right under the flap where the ink would sit when printer is powered off
(d) underneath there is something in white that is flat - this is called a wiper.
(e) push this wiper with your fingers - pushing in the direction toward the front of the printer - you may need to do this a few times.
(f) power off and then power on (using button on the front and NOT by pulling the power out of the back)
Hopefully error should go after you attempt this a few times!
Feb 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
348 people viewed this question
old marine
old marine
