Question about HP Compaq Presario SR1250NX (PJ534AA) PC Desktop
My sr1250nx won't power up. blinking green light in back right below power cord
  • 81 Answers
Generally in dese cases its a HW problem> open up the side panel> disconnect the thickest bunch of power cable on the motherboard(ATX connector) it either has a 20-24 pin connector> then turn on the PC> if the Light at th back is steady> the motherboard has gone bad> if its off> the power supply has gone bad
Posted on Oct 07, 2009
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
The green light on my prince lionheart warmer won't stop blinking
I realize the original question is 2 1/2 years old but for future answer searchers... the flashing light means your power cord is no longer working.
Jan 18, 2013 | Prince Lionheart Premium Wipe Warmer
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
My computer want power up the green led light is on
if the green light is on then the computer is powered up, i suspect u have a defective monitor, not that uncommon, the olny way to check it is have a computer repair shop hook it up to another working system and see if the monitor turns on, if it is the monitor just replace it, monitors are very cheap right now, just bought a 19" for $89.00, mine did the same thing, green light nothing on screen.
Jun 09, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
Computer wont turn on or off
power unit PSU dead is there a fan motion ? beware of PSU that sleep in the night ... mine did it and destroyed the syste, also the auto safety may have dumped out and it will not resume unless the system is repaired, could be power or maybe an internal chip Memory short, processor dead, fan stopped inside ... never run without it there may be a loose connection stopped fan . Mike
Jun 13, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
HP Compaq Presario SR1250NX (PJ534AA) PC Desktop Logo
264 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
