Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
My idle is struggling
I am having a power problem, I made the mistake of touching the high/low idle adjustment screws now I find myself not being able to get optimum performance out of my Poulan 38cc, what is the proper aproach to making the adjustments?
    Sergeant:
  • 302 Answers
Start out with both of them set at 1 1/2 turns out and then fine tune from there if needed. hope this helps you
Posted on Oct 06, 2009
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Continuous high idle and idle screw no help
Does your artic cat have a carb cable if so it will have an adjustment or a clamp on the cable where it attaches to the linkage..check make sure it is set to low idle..and your idle screw is adjusted to low idke..meaning cable adjusted to lowest possible position when the throttle is released..then make your final adjustment using you idle screw..good luck
Oct 22, 2014 | ATVs
How do you adjust and which screw is the Idle air mixture screw?
The idle screw is the largest of the three and will generally have spring on it and it will be above the low and high adjusting screws. Turn the idle screw clockwise to increase idle speed. But before you do that, adjust the low and high settings to one full turn out.
Aug 29, 2014 | Troy Garden
Need to tune sthil fs74 line trimmer
Hi chris tanti
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Oct 13, 2012 | Stihl Garden
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Lev90 120 carb
Hi Charles Gregory
Bud
Oct 01, 2012 | Garden
How do I adjust the carburator?
There are two needle screws that can be adjusted to make the engine run properly. Be certain that the carburetor is clean and the diaphragm is in good condition, and the fuel is new. The two needle screws mentioned above should initially be adjusted at one turn open from turned in all the way (lightly seated). Each of these needle screws performs different functions. One is for idle and throttle response (this screw is marked "L" and the other screw is marked "H". L and H are marked on the carburetor body and also on the plastic "shroud" near the adjustment screws. These screws are not interchangeable, being foolproof since the thread sizes are not the same. When properly adjusted the low speed screw (L) allows the engine to idle properly and throttle response will work properly. When the high speed screw is adjusted properly the engine will have correct power at full speed. Adjust the low speed screw so that the engine idles and when you squeeze throttle all the way to wide open the engine should not hesitate and should come up to full speed and when you drop the throttle it should idle nicely without stalling. Now adjust the high speed screw. Hold throttle wide open, holding it there while you adjust the high speed screw. If this scares you (be carefully so that the spinning chain does not cut you!) you may adjust the high speed screw at idle, turning it just slightly in or out. The high speed screw should be adjusted so that the engine does not run clean at wide open throttle but sputters slightly, slightly adjusted open from running clean to slightly sputtering. When under load (cutting a log) the engine should run clean. Good luck!
May 21, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a older model # 30 jiffy ice auger and i can not seem to keep it running consistanly. I was wandering what the carburator adjustments are. The low idle screw and the high idle screw where do I start...
Hello Randy. I can talk you through making adjustments to your Jiffy ice auger engine.
1. Read through the whole list before you start adjusting.
2. Close both jets GENTLY
3. Open the Low speed 1/4 turn
4. Open high speed jet 1 1/4 turn
5. Start engine.
6. Adjust low speed until idling smoothly.
7. Open her up wide open.
8. Adjust High speed until engine transitions smoothly from idle to high speed without bogging.
9. Shut engine off. Let it cool.
10. Once engine is cold. Fire it up and let it idle for 30 secs. Open it up wide open again. Adjust if necassary.
NOTE 1: The trick with the Jiffy's is to tune them during cold (ice fishing) weather.
NOTE 2: Low speed screw,the one on the left.
NOTE 3: High speed on the right.
Good luck ice fishing! Regards, Joe
Dec 31, 2009 | Sport & Outdoor - Others
Screw adjustments for partent consaw k650 super
older partner saws have a high,low and idle screws.the high and low are side by side.the bigger screw below them is the idle screw.first take the high and low screws and run them in clock ways.don't tighten them,just snug.now back them out one 1 turn each.then start saw. let saw come down to idle.if saw does not idle turn the ilde screw in until it does.now throttle saw up to full throttle and turn the high side screw in just a touch 1/8 turn,no more.let saw come back to idle and back the idle screw out until the blade stops. all done now. hope this helps,let me know
May 19, 2009 | Garden
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
212 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
