Question about Hotpoint Ultima WF860 Front Load Washer
Water is not getting hot even on highest setting
    President:
  • 1,187 Answers
Is this a new installation or has been working for a long time?
Has the wash water ever gotten hot?
There are two water supply hoses. Which one is hot? Does the hot water supply hose feel hot?
If new, the two water supply hoses are reversed.
If in place, and worked before, then possibly:
1. Hot water heater not hot enough.
2. In-wall heater can't keep up with demand.
3. Water pressure too low (open water valve)
4. Water valve(s) in washer not working properly. (service, replace)
Posted on Oct 05, 2009
    President:
  • 1,653 Answers
Check that the wash temperature has not been turned down accidentally. If not, then the most likely and obvious cause of this is the element has become faulty and needs replacing. This could also be caused by various other problems such as a faulty thermostat, resettable fuse links or activated over temperature detector, fused links in the power supply, faulty logic board, etc. Call a service engineer ASAP.
Audi 2.5 tdi sport 2005,heater is going hot and cold on highest heat setting
vent the hot water system.....undo the highest hot hose clip to vent air,if problem persists then replace thermostat.
Oct 20, 2010 | 2005 Audi A4
Rheem hot water system- Not getting hot enough.
sound like the mixing valve is damage.. even though the valve is mandatory rheem tankless system don't really need one due to the fact you can set the temp to avoid scalding..these unit will only go up to 120F (48C) The only reason you wll need a mixing valve is when you store water because you have to mantain a temp to kill bacteria and since there is no storage on the tankless it just does not make sense to have one. also you can turn down the temp on the control at anytime to any desire temp..this is a plumbing regulation in many part of the world that need to be look at a little more carefully..not only where you live.
Jul 03, 2010 | Rheem Water Heaters
Storage hot water system sounds like its crackling when filling after water use.system is 7 yrs old
check your thermostats and see if they are set to highest setting. Sometimes if theya re they will pop and crack when filling back with cold water.
May 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
I have a Brizo Shower and can't get the water hot enought
I am not sure but I think the shower will work with out the limiter on it .  try that
Apr 14, 2009 | Delta Plumbing
Water in shower not very hot
It could be possible you require more water volume, so take off both panels on youur water heater and check what temp. they are at.
I know I discovered the hard way there are 2 heaters and 1 of mine was low,good luke.
Mar 25, 2009 | Pegasus Technologies Home
Not enough hot water. I have an Amtrol Extrol coil water heater
Since you mentioned 'both temperatures' it seems your unit is like most all of them, a lower and upper coil.
If your hot water supply runs out quickly, this normally means that the lower coil has failed. Since heat rises, the upper coil will never supply a tankful of hot water, just hot to start, and then as the flow continues, it doesn't have time to do more than warm the water flowing into the tank.
Every home should now own a simple digital multimeter; they cost less than $20 US everywhere and one can find them in auto parts stores, electronic supply companies and tool companies.
If you have a Harbor Freight tool store in your area, you can get them for under $10 US any time and sometimes even less:
Digital meter
You need to be absolutely certain that the voltage to the water heater is shut down. Before you measure anything else, set the meter to its highest AC setting and check across the coils and then from either contact to the metal housing. If it is dead everywhere, then set the meter to the lowest Ohms scale (normally 200). The resistance of the coil should be nearly the same reading as when you simply short the meter's probe tips together. If it measures 'OL' then the coil is open and must be replaced.
Feb 26, 2009 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Heater issue - only works when on highest setting
this is caused by the blower motor speed control resistor being defective, this part is located near the blower motor.
Oct 30, 2008 | 2000 Chevrolet Prizm
Hotpoint Ultima WF860 Front Load Washer Logo
105 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
