PIONEER VSX-605S Stereo Receiver ''OVERLOADS'' and shuts down.
I have a PIONEER VSX-605S Stereo Receiver.
I have Polk Audio Speakers attached to it. The speakers take 2 connections to the back: 1 connection for the highs and 1 connection for the lows. It's like having 2 sets up speakers hooked up. I know they are Polk Audio because of the covers, but they have no other information on them as far as model # or impedance information.
Now for my problem:
If i just have the Front A speakers on, I can go as loud as I want with volume.
If i turn on the the Front B speakers (which are the highs or tweeters i guess) the display reads: ''OVERLOAD'' blinks and shuts down.
Why is this? No other attached components are turned on. I am just using the radio tuner and one set of Polk Audio Speakers with 2 sets of connection for Front A and B.
thanks.
  • 979 Answers
SOURCE: overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Posted on Nov 26, 2007
  • 319 Answers
SOURCE: Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Posted on Aug 14, 2008
smarthome2
  • 1114 Answers
SOURCE: new pioneer vsx-517 keeps going into overload
Fastest way to test is to disconnect all speakers and turn up the vol. If it clips it needs service, then re-connect 8ohm speakers one by one and test until you find the speaker or channel that shorts. Then take that same speaker and hook it up to another channel and test, if it shorts, you know now it is either the speaker or the wire. Now, use a new piece of speaker wire from the same channel that caused it to short, replace the old and test. If it shorts, you've got a problem with the speaker. If your handy with a multimeter, check the resistance at the speaker and you will have your answer. If you are not familliar with a multimeter, just hook up a different speaker where the bad one is and test. It's just process of elimination. Hope this helps
Posted on May 25, 2009
smarthome2
  • 1114 Answers
SOURCE: Owners book / manual for Pioneer receiver VSX-605s
www.pioneerusa.com then support. I could not find your "Exact" model, and it could depend on where it was purchased. Look at units closely labeled to yours and chances are it will be the same with a different #. Hope this helps
Posted on Aug 16, 2009
  • 14 Answers
SOURCE: Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Posted on Apr 17, 2010
Owners manual for pioneer vsx-605s
Try Googling (pioneer)(vsx-605s)(manual) without parens.
Oct 07, 2017 | Pioneer Audio Players & Recorders
Hope this helps.
Apr 16, 2010 | Pioneer EliteĀ® VSX-01TXH 7.1 Channels...
Receiver shuts off as volume is turned up beyond
try connecting only 1 speaker at a time. try it on each of the binding posts (connection terminals), crank it up to locate which one of the speaker terminals is overloading the amplifier.
Then connect a different speaker to that terminal to see if it still overloads. This should determine if its the speaker that is overloading that particular terminal or if something is wrong with the amplifier.
Just for fun make sure that the cables you are using don't have any fraying and that none of the speaker binding posts have any loose strands of wire possibly grounding out to the chassis of the receiver.
Dec 30, 2009 | Pioneer VSX-819H-K A/V Receiver
Aug 16, 2009 | Pioneer VSX-505S Receiver
Receiver - manual service
Still need to solucção pioneer VSX-605s and-505s not VSX. I want to thank the provision of his plan. I am more in search of the manual services of receiver VSX-605s ....
Oct 14, 2008 | Pioneer VSX-505S Receiver
Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Feb 10, 2008 | Pioneer VSX-505S Receiver
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Overload Problem
Dec 04, 2007 | Pioneer VSX-D608 Receiver
253 people viewed this question
 Grubhead
Grubhead
