Question about KitchenAid Dishwashers
I have a kitchen aid quiet scrub dishwasher and I am noticing some suds comming out from under the door and a very small amount of water on the floor from this
  • 120 Answers
This is definitely a seal problem. Check all seals and replace as required.
Posted on Oct 05, 2009
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
How do I remove the suds after having used regular dishsoap instead of dishwasher soap?Kitchen aid dishwasher
you will just need to run it a few times. I know of no way to kill bubbles except to dilute them.
Oct 13, 2014 | KitchenAid Kitchen Aid - KUDS30FXBL...
My GE Profile Quiet Power 2 is leaking soap suds through the bottom of the door. Any advice what to do?
dishwasher soap does not suds up.you have a different type of soap in there.the only way to remove it is dumping cold water inside then running it. find where the soap came from so it wont happen again.possably the rinse aid?
Mar 02, 2010 | GE Dishwashers
SUDS COMMING FROM UNDER DOOR OF KITCHEN AID DISHWASHER
This is usually too much soap or the wrong kind of soap.If you are using the recommended amount of the right kind of soap, you may have very soft water, causing excessive suds. Try cutting back on the soap
Dec 13, 2009 | Cars & Trucks
Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Oct 01, 2009 | KitchenAid Washing Machines
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
"clean" light is blinking
Check the following:
1. Is the overfill protection float able to move up and down
freely? Press down to release.
2. Be sure the water supply is turned on to the dishwasher.
3. Check for suds in the dishwasher. If foam or suds are
detected by the dishwasher sensing system, the
dishwasher may not operate properly or may not fill with
water.
Suds can come from:
1. Using the incorrect type of detergent, such as
laundry detergent, hand soap, or dish detergent for
hand washing dishes.
2. Forgetting to replace the rinse aid dispenser cap
after filling (or refilling) the rinse aid, or spilling rinse aid into the tub (rinse aid causes suds to occur).
3. Using an excessive amount of dishwasher detergent.
Mar 16, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishwasher was full of soap suds but most of the water drain
Suds? If you use dishwashing detergent you shouldn't get suds. If a small amount of sink type dish soap is left on a dish before loading it into the dishwasher this can happen. I would use several rinse and drain cycles with the racks and dishes removed until the suds are gone.
Never use any type of liquid dish soap made for sinks. The same thing that makes suds in the sink will make even more in the dish washer.
Hope this helps!
Feb 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Suds and water staying in Whirlpool Quiet Partner III
I believe you may be over sudsing, Try a few cycles with vinegar and no soap. Do not use dishwashing soap at any time ever. See if the vinegar trick helps...helijm
Dec 01, 2007 | Dishwashers
Dawn detergent in rinse aid dispensor
I did the same. I have run the washer several times but with the rinse aid cup open. Then flushed it by adding water and using a turkey baster to **** the water out. Then used a small amount of liquid fabric softner to reduce the suds. Then flushed it several more times with clear water. The turkey baster will fit into the cup better if you can remove the inside cup cover that dials the amount of dispensing (at least in my brand of dishwasher). I also forced paper towels into the cup opening several times to sop up as much liquid as possible until the indicater light for rinse aid showed empty.  This took some time but by the end of the day, the suds diminished.  Note: I no longer keep Dawn under the sink cabinet where the rinse aid is kept!
Oct 13, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwashers Logo
194 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
