Question about Panasonic Office Equipment & Supplies
Panafax uf-322 info code 016 carriage cannot move message. Is there a simple fix?
    President:
  • 3,085 Answers
No simple fix.
Open the top cover, turn machine off.
Move the ink carrier to center, knock off the tower of dried ink with a letter opener.
Oil the chrome shaft.
Clean the plastic strip in back of the ink cart with soapy water.
Posted on Oct 06, 2009
Testimonial: "Thanks, FixinFax, kind of you to reply!I found some similar advice, and used my husband's elec razor disinfect/lubrication solution to do the cleaning"
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error Code i can't fix
The main drive motor is stalled or not turning.
Pull out the toner cart and see if it runs.
Mar 17, 2009 | Panasonic Panafax UF-990 Plain Paper Laser...
ERROR CODES 016 AND 010
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Pnafax UF-322
do you get the error code immeditely after turning it on or shortly after on
Thank You,
Mikey
Apr 03, 2008 | Panasonic Panafax UF-333 Plain Paper...
Panafax UF-333 No Print Cartridge Error
Pls check in foll order: A.replace with another cartridge. B clean the contact points on the cartridge and the cartridge holder. c.check wheteher the carriage is stuck or too hard ,then oil the rod a bit. D.Please check whether the plastic portion of the carriage wher the cartridge rests may not have broken ? E.The carriage cable may have got cut . f.the carriage sensor might have gone,Please replace the carrriage cable with sensor.. Happy Faxing Omnipresent
Nov 22, 2006 | Panasonic Panafax UF-333 Plain Paper...
272 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
