Question about Olympus FE-26 Digital Camera
Picture clarity I am having trouble making my picture clear, I've played around with the shutter speed and all but I just can't seem to get a picture that isn't blurred. I don't have the steadiest hands but that shouldn't be the problem because I've used other olympus cameras and haven't had this issue. I don't have directions on how to use it or what the settings should be, please help.
  • buddhiman651 May 11, 2010
    Here is your Solutions
    » Canon » Fuji » Kodak » Nikon » Olympus » Panasonic » Samsung » Sony
    buddhinma2
Slow snapping picture
I am not sure, but have you played with the camera manual setting ?
if you did
you should change the shutter speed to a higher level (if you have used the manual mode)
but if you use the automatic mode and the light around you was low the shutter speed will be automatically low so the camera could give you a better picture be lowering the shutter speed so it could have the enough time to collect the light (that's why the snapping is slow)
so try to increase the iso or the av (lowering the av's number)
hopefully, I have helped you
Mar 06, 2014 | Minolta Maxxum 400si 35mm SLR Camera
Need to resize pictures
The size is going to be based off of clarity per pixel, the higher the MP the more pixels in turn the larger (but more clear) the picture.The best way to keep the clarity would be to resize on your computer, if you have windows, open the picture(s) with PaintStart Menu -> Programs -> Accessories -> Paint
Then after you've opened the picture, do the followingWindows XP -> click "Image" then "Stretch/Skew"Vista/Windows7 -> Click "Resize"Make sure you keep aspect ratio percentages locked or you'll come out looking like a circus image.
Jan 25, 2012 | Canon Powershot SX110 IS Digital Camera...
My husband pulls tractors at night at tractor pulls, everytime I try to get a picture its too dark, the lighting around the pull isn't the greatest but it has some light
There are several solutions to taking pictures in the dark or low light. Night time photography can be difficult without a tripod. There are three ways you can get a brighter photo
1. Larger aperture - Make sure the aperture is set to the lowest f-stop for the largest aperture. f/2.8 or f/5.6 depending on your lenses capabilities. Choose the lowest number
2. Longer shutter speed - A longer shutter speed will allow more light to hit the canera's sensor and create a brighter picture. Unfortunately with a longer shutter speed, you will probably need a tripod because the photo will come out motion-blurred otherwise.
3. Higher ISO - A higher ISO will make the camera's sensor more sensitive to light and therefore creating a brighter picture without having to have a longer shutter speed. High ISO, however, can introduce unpleasant noise/grain to a photo.
If you want to take your picture while holding the camera in your hands, I recommend the largest aperture (small f/stop) and a high ISO.
If you have a tripod, use it! and use a longer shutter speed since the tripod will hold the camera steady for you.
Jul 09, 2011 | Nikon Cameras
Nikon D60 is working slow.
I would start with a freshly formatted memory card. Erasing images leaves folders and other unneeded data on the card which can slow the write speed down considerably. Secondly, make sure the front and rear elements of the lens are spotlessly clean. The auto focus works best (faster) if it can see the subject with perfect clarity.
Nov 28, 2009 | Nikon D60 Digital Camera
Webcam picture clarity
It can be bcoz of multiple reasons. First make sure you have good internet speed 512 kbps or above or it is also possible he is using low pixel camera.
Thanks,
Jul 10, 2009 | Logitech Quickcam Chat Webcam
Shutter speed very slow and has trouble focusing. When I press the the shutter button it takes several seconds before it takes a picture if at all. It seems as though it is having trouble focusing and when...
There is a diaphragm between the shutter button and the shutter switch that causes the camera to focus before the shutter is pressed all the way down. It is likely that the diaphragm is punctured and needs to be replaced. There is also a small possibility that the hidden secondary battery inside the camera is going bad.
Jun 06, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Every time i take a picture with my nikon d-40 the pictures are blurry. the camera is on auto focus but i can't seem to get the picture to come out clear. any suggestions?
Is your shutter speed fast enough? If not, you'll need a faster shutter speed or a tripod.
Are you using the proper focus sensor? Is the entire image blurry or just portions of it?
What happens if you focus manually? If it comes out sharp, then there's a problem either with the lens or the autofocus system on the camera. Have you tried it with a different lens?
Is the AF switch on the lens set to A?
Jun 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Blur on fast moving objects
Try lowering the quality of the pictures. It will allow a faster shutter speed since it doesn't need as much data to make the picture. Try throwing a ball into the air and playing with the settings until you can get what you need.
Jan 21, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
Y NO CLARITY THEN OTHER CAMERAS????
reset camera or try to slow the press down speed during picture taking... if you mash down the shutter button fast, the pictures tend to be less than desirable with any digital camera
Jul 06, 2008 | Olympus Stylus 720 SW Digital Camera
S650 cybershot lens problem
he apparture / shutter blade mechanism of the camera is not working fine. Needs repairs.
Jan 21, 2008 | Cameras
Olympus FE-26 Digital Camera Logo
51 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
