Question about GE Spacemaker JVM1640SJ Microwave Oven
Will not rotate
The turn table will not rotate. Motor?
Called a local repair man no charge just free advise
Posted on Oct 06, 2009
  • GE Master
  • 9,098 Answers
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here, but if your brand is not listed, try Encompass or call them toll-free at 866-779-5835.
Turn table wont turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 05, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
My daughter just moved into a townhouse and the microwave plate warms, however the plate doesn't rotate. Is there any easy way of fixing this issue
The rotating table in a microwave shouldn't be getting warm unless something is sitting on it and transferring heat to it. The chamber should not be left empty when the microwave is running. The motor that drives the table is of very low mechanical power but should be able to handle about any load it must. I suggest you remove the glass table, the ring on which it rides, put a cup of water in the chamber and turn it on. Look at the drive spindle that engages with the table when installed. If it isn't rotating 9should be easy to see) then the motor is defective which is highly unusual to see one fail. If the spindle is clearly not moving, then I recommend replacing the whole unit since while the part isn't expensive, the labor cost would likely make the repair uneconomical.
Dec 22, 2010 | GE Microwave Ovens
Turn table does not turn The GE Microwave oven woprks very well however the turn table does not turn any more. It is supposed to rptate as it cooks.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 23, 2010 | GE Spacemaker JVM1540 Microwave Oven
Plate will not rotate
Yes there is a small gear reduction type motor that drives the turn table. The motor can be replaced.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating
HI. The most common issue here will be a failed turn table motor. This motor is located beneath the actual table housing. replace this failed motor.
Note(The uncommon problem area will be a failed relay. although, highly uncommon, this may be the issue. i would advise to inspect the motor control relay located on the main control-board for visible burn marks)
Oct 03, 2009 | Hotpoint Microwave Ovens
My convection/microwave quit rotating.
Hello Tina,
Usually those turn tables(or lazy Susan's colloquially) are driven by a small motor. The motor attaches to a gear or spindle which transfer the rotational energy to the turn table. A plastic gear may have been broken or popped loose. It might also use a belt to transfer the energy, the belt could have worn and is now slipping which would cause the table to stay stationary.
Aug 10, 2017 | Sharp R-370E 1000 Watts Microwave Oven
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Dec 21, 2008 | Microwave Ovens
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Sharp Microwave turn table turning irregualrly
You can see and hear a YouTube video of how a turntable motor should sound when you rotate it by hand.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can probably find an exploded view and order parts by entering your model number here: http://www.searspartsdirect.com
Sharp parts are usually less expensive when ordered from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
71 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
