Question about Hotpoint Dryers
I have a tumble dryer.
I have a hotpoint aquarius dryer plus TL62. Put clothes in, shut door (sometimes will start tumbling without door being shut) it may work for a few minutes then stops - light goes out. If you give it a knock just around the door the light flickers briefly. Sometimes it starts again but mostly it wont! Many thanks. C Hudson
  • Hotpoint Master
  • 7,482 Answers
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Posted on Oct 05, 2009
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
Mar 01, 2015 | Hotpoint Dryers
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Aug 06, 2013 | Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Tumble dryer drum won't turn
Jul 06, 2009 | Dryers
Tumble dryer
Go to:
www.hotpoint .co.uk
Click on After sales, then on download user instruction books, put in you model number, and down load to your computer, or your printer.
Problem solved.
Plz rate my solution.
thanks, and merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint vtd20 dryer aquarius - cuts out when overheats
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Dec 10, 2008 | Hotpoint Aquarius WD640 Front Load...
My hotpoint vtd20 tumble dryer will not start. I was using it then when I put a second load in and pressed start - nothing happened. The power light is on but no tumbling!
If you can hear the motor running but no tumble action then belt has come off.
Make sure the door is shut properly..
If it gets hot at the back, then you are difinately getting power to everything.
If you can hear a slight buzzing noise, then the motor is failing to start, probably due to a faulty start capacitor.
Dec 08, 2008 | Dryers
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
256 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
