Question about Canon PIXMA iP4000 InkJet Photo Printer
When it stopped printing the printhead was removed and washed with alcohol. Still not printing colour. Occasionally will print only black but sometimes not printing at all.
VOTIT
  • 2071 Answers
SOURCE: Black-Red-Green-Photocyan-Photomagenta not printing
Are you using compatible cartridges? If so have you removed any tape that covers the vent hole if required. Many compatibles need to have a piece of tape removed. If you forget the ink cant get out as the air can't get in.
If it not a piece of tape and there are no flashing lights it could be that the nozzles are blocked or the wick has dried out.
You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
With the top of the machine open, you should be able to move the print head carriage by hand.
Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick.
Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor.
There is another possibilty after this which relates to a hardware problem but this generaly causes a loss of all ink.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Jul 29, 2008
SOURCE: How do I remove a Canon 730 Multipass print head
Press the button on the right hand side of the printer. Lift the lid, pull up the little gray handle. Rock the print head container a bit and you'll see a little metal bar. Grab that and pull straight up.
Posted on Jun 13, 2009
cene765
  • 787 Answers
SOURCE: printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Posted on Nov 12, 2009
  • 73 Answers
SOURCE: Canon IP 90 clogged printhead nozzles. How to remove printhead?
To avoid drying of the Print Head and clogging of the nozzles, note the following.
*When you turn off the Machine
Follow the procedure below to turn off the machine.
1)Press the ON/OFF button to turn off the machine,
2) Confirm that the POWER lamp has gone out.
This takes a few seconds or as long as 20 seconds.
3) Unplug the power cord from the wall outlet.
If you are using a power outlet strip, you can switch off instead.
When you press the ON/OFF button to turn off the machine, the machine automatically puts a protective cap on the Print Head to prevent the ink from drying. If you remove the power cord or switch off the power outlet strip before the POWER lamp goes out, this capping will not be done properly, causing the Print Head to dry and clog.
* When You are not Using the Machine for a Long Time.
When you are not using the machine for a long time, print or copy in both black and white and in color or pertorm Print Head Cleaning, about once a month to prevent degradation of the Print Head.
Numerous nozzles are installed in the Print Head for high -precision printing. Just as the uncapped tip of a ballpoint pen or marker becomes dry and unusable if it is not used for a long period of time, the print nozzles becomes blocked by dried ink. Periodically printing or cleaning of the Print Head can prevent this blockage.
Note :
*If the printed area is traced with a highlight pen or paint-stick or stained with water or sweat, ink may blur depending in the paper.
*If the print head nozzles get clogged , printouts will become faint or particular colors will not be printed properly.
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
The pattern print confirmation screen is displayed.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
1)
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Posted on Nov 30, 2009
SOURCE: CANON MP600 - NOT PRINTING IN BLACK INK
I have had the mp600 for 3 years - worked fine on a couple of different pcs. I switched to a mac and encountered 2 issues - scanner stopped working and above problem of no black ink. The newest driver (just google mp600 driver) fixed the scanner issue. The ink issue has a work around - select non plain paper in the media quality tab, instead use any photo paper setting. Finding this area in a mac can be tricky - in the mini print options window you have to click the small chubby arrow and you will then be given a list of options including quality and media. Presto, black ink returns but probably uses more ink and takes longer to print. I have not found a more elegant solution as you have to select this non default paper option every time.
Posted on Feb 07, 2010
LX810 Label Printer is printing out labels that are the wrong colour. Oranges are pink, darker colours are pink, and some are purple. I have swapped out the ink cartridges and the problem is occurring. Any...
It's time to clean the printhead. Use the procedure from the printer status monitor. Try cleaning several times but beware it will drain some extra ink from the cartridges. If the cleaning process will not increase the quality of print, probably you will need to replace the printhead. Before replacing printhead, remove all the cartridges and verify if all four gaskets (seals) are present on the inner bottom of the printhead. Also remove printhead, clean contacts both on the back of printhead and carriage with isopropyl alcohol. Put back printhead and cartridges and let the printer do its ink system initialization process. Then try to print your labels again. If all those attempts fails, replace printhead.
Apr 30, 2014 | Primera Technology Primera LX810 Color...
HP photosmart B210 wont print black
Seems to be a common problem - I had it too. I spent a lot of time looking, but never quite found a consistent fix. I fixed mine in a few steps: First, I removed all the cartridges, and cleaned the filters on the top of the printhead (these are the little screens you see when you look at the tray with the cartridges removed). To do this I blotted each screen with premoistened alcohol wipes, changing wipes frequently, until the wipes were clean. I then removed the printhead by lifting the black handle on the right side, and lifting the printhead straight up. I used alcohol pads on the rear contacts (refer to HP's instructions for changing printheads) in a downward motion only. Finally, I cleaned
Nov 10, 2012 | HP Photosmart Plus B210A Multifunction...
Ink is printing streaky, but this is my second brand new ink cartridge. Any suggestions?
this symptom signals blocked printhead, you need to do bit of cleaning, not necessarily cahnge the cartridge.
follow this procedure:
1. download test page with alternative from this site black:
http://www.inkjetcartridges.com/_black-print-test.html
and colour:
http://www.inkjetcartridges.com/_color-print-test.html
2. print page each and assess the colour and streaks. if on the beginnig of the page you do have errors and on the bottom all is corrected, this meant that you just cleaned your printhead nozzles and problem is solved.
3, if problem persist, from stationery store purchase few pages of absorbent paper, weight of about 120 to 160, do not use thicker than 160 and print these colour pages again,
4. print control page again and see if any improvement was made, if there were no changes, follow this procedure:
a. remove cartridges from craddle
b. determine what is ink solvent, water, isopropyl alcohol or methylated alcohol - correct solvent will be that which do not precipitate or curdle the ink
c. touch with absorbent tissuebottom of the cartridge and check if it is leaving even print, if not, whipe once with solvent
d. put a drop of solvent on gold/silver buttons inside of the craddle, allow to sink for about a minute, whipe off with absorbent tissue
e. put again a drop of solvent on the button in the craddle and insert ink cartridge
f. print test page, page will be very weak on the top (solvent print first!) and improve as it prints down, if necessary, print again colour or black test page from 1.
this should solve your streaking head problems, if they still persist, this meant that print heads are really well blocked by caked ink and usually is cheaper to change printer than change the head in it...
if you find this advice useful, please do not hesitate to leafe your feedback and vote for me, thanx!
Jul 31, 2010 | Canon PIXMA MP470 All-in-One Printer
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My MP500 has stopped printing black (there is a new cartridge installed). - The colours appear to print as normal. Any ideas how I might sort this problem? Thanks.
This can happen when the print head becomes caked in ink. Generally, it is cheaper to buy a new printer than to purchase and replace the print head. Some people suggest cleaning with a q-tip and alcohol, but I haven't had much luck with that. It is also possible that the new cartridge is defective. try returning it and get a new one to try.
Dec 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
I replaced a new black ink catridge, the black is
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • Try changing the print quality to best then try printing
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 23, 2009 | Kodak ESP 5 Printer
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Epsom R340
print a nozzle check from the maintenance menu
see which colours are missing, run through a few head cleans and print another nozzle check see if there is any improvement
also replace the cartridges of the missing colour they may be dried up. have seen this before where a 3/4 full black cartridge just completely stopped printing
if the problem still persists then get a syringe or an eye dropper and some form of spirit (I have used vodka in the past but clinical alcohol is recommended as not as sticky)
choose change cartridges from the menu then remove the power cord. with the cartridges removed you now have access to the printheads.
using the syringe (or eye dropper) place the nozzle on the spike that goes into the cartrige and inject a small amount of the alcohol leave this to soak for a few mins then mop up the excess with a cloth repeat this a couple of times put the ink back in power up and run another head clean (you can also put afew drops on the spounge that sits under the print head during the head clean
print the nozzle check again you shoudl see most of the nozzles are now working run another head clean if desired now try with a pic
have used this on various epson printers including a stylus 700 R340 & 360
Jul 27, 2008 | Epson Stylus Photo R340 InkJet Printer
Will not print in black
Try running the printhead cleaning utility on the printer a few times. Sometimes if you do not use your printer enough, the ink can clog the printhead on the cartridge. Another thing you can try is to use a cotton swab with some alcohol on the printhead to try to loosen it up. The alcohol trick is a last resort because it may damage the printhead occasionally. Good luck!
Apr 22, 2008 | HP PhotoSmart 7760 InkJet Printer
Black cartridge does'nt write
the black ink u are using is not compatible with print head. i suggest u using original ink by buying original cartridge
Dec 30, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
13 people viewed this question
old marine
old marine
