Question about IBM Lenovo ThinkPad T61 6466 Notebook
Thinkpad T61 Battery Problem
I've had my t61 close to a year now and the battery has been doing just fine, lasting about 3 hours and 30 minutes on a full charge. Then about a week ago when I clicked on the battey icon I got a message saying "consider replacing your battery". My battery was still working okay even after the message until yesterday when it just stopped working. When i click on the battery icon it says the battery is 100% charged but the computer goes off as soon as i disconnect the power cable. I want to know if there is a way i can fix this or do i just have to buy a new battery??
  • 408 Answers
You probably should get a new battery or at least a good used one.The battery icon is saying 100% but its at 0% because the battery is malfunctioning.
Posted on Oct 10, 2009
Replaced keyboard for thinkpad t61 now will not POST
I'm sure you removed ALL power from computer before repair. Unplug, remove battery, reseat Memory Mods and HDD, boot normally.
Dec 13, 2012 | IBM ThinkPad T61 (64574XU) PC Notebook
T61 thinkpad does not detect battery
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Oct 21, 2010 | IBM Lenovo ThinkPad T61 Notebook
Lenovo T61 Battery life 10 min? Any advise?
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Nov 09, 2009 | Lenovo ThinkPad T61 Notebook
Ibm t61 turns on but all I get is a blank black screen.
This sounds rather bad. You're not even getting a "thinkpad" screen?
Try unplugging the power and removing the battery for a minute and attempt to power up again.
If it's still not starting, try removing the memory modules (if there are two, remove one and try powering up, then try to remove the other one). Although I seem to remember that newer thinkpads will still show thinkpad logo and attempt to POST even with bad memory (then throw an error), it's always worth a try.
If the above don't make any difference then I'm afraid most probably your motherboard has failed. In theory you could also try swapping the cpu-I've seen a cpu go bad ONCE in my several years of tinkering with laptops.
T61 is a current model-wouldn't it still be under warranty from lenovo? Might be worth checking the serial on their website. Otherwise it's time to search for T61 donor laptops on ebay - ordering a new motherboard from lenovo parts suppliers will most probably be far too expensive.
Good luck, hope you get it working again!
Raf
Thinkpad T61 went dark abruptly after startup
Make system restore, or better reinstal vista from IBM image file, dont install any updates, go get windows 7 , and get rid out of vista.
Oct 31, 2009 | Lenovo ThinkPad T61 Notebook
your battery may suffer from'memory-effect'
due to overcharging several times.
boot up as usual, switch laptop to standby-mode
and let it switched on until it shuts down automatically.
this will help to drain the battery to a very low level.
recharge battery until full capacity while laptop is still shut off, boot and measure time until it switches off again.
You may have increased battery capacity this way a bit! If this does not help, get a new one with a better capacity and remove battery when your using laptop at home for a longer time(this will prevent future overcharging), rely an ac/dc adaptor instead, laptop will funtion anyway.
Jun 13, 2009 | IBM Lenovo ThinkPad T61 6466 Notebook
I have an IBM T61 that will not power on.
Power supply may have been hosed. Another thing to try is to plug the A/C adapter in but do NOT have a battery connected. If it powers on then there might have been a problem with the both batteries. Also be sure nothing else is connected to the computer's ports. Especially any external video devices.
Mar 04, 2009 | IBM Lenovo ThinkPad T61 Notebook
How to remove the battery from lenovo T61 and put it back in?
the instructions below are from the owners manual page 69. you can download the manual with accompining pictures to guidr from the link below: ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/42x3547_04.pdf
Table 11. Removal steps of battery pack Unlock the battery release lever 1. Holding the battery release lever in the unlocked position 2, remove the battery pack in the direction shown by arrow 3. 312 When installing: Install the battery pack along the slide rails of the slot. Then make sure that the battery release lever is in the locked position
I;ve spent my time to solve you're question, please show the good grace to at least take a few seconds to rate this answer.
Feb 01, 2009 | Lenovo ThinkPad® T61 PC Notebook
IBM Lenovo ThinkPad T61 6466 Notebook Logo
499 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
