Question about Pioneer SD-P55A3-K 55" Rear Projection Television
Tv Fuse Blown
I have a Zenith Big screen and During a Storm a tree limb knock down the Power line causing the Neutral to become disconnected, I had an extra ground installed. No after having the power restored My tv wouldn't power up, so I removed the back and found the 6 amp fuse blown, I found a 5 amp fuse at the local radio shack. I installed it and it blew as soon as I plugged it in. would 1 amp make that much difference? or would there be more wrong with the TV?
    Scholar:
  • 90 Answers
Depends on how hard the fuse blew. If softly, perhaps 1 amp diff is too much.
If hard - blackened inside - then you need to call in a tech.
Mr Bob
www.imageperfection.com
Posted on Feb 07, 2008
While parked a tree branch fell on the truck now it won't start it ran fine before the tree branch fell
A Tree Fell on Your Car: Now What?-Allstate
https://www.allstate.com/tools-and.../car.../tree-fell-on-car.aspx
Allstate... parking lot to avoid door dings," so you can imagine his dismay when a tree ...Gregg did his best to salvage his truck after the storm passed, but the ... If you're the owner of both the fallen tree and the vehicle, your homeowners insurance policy likelywon't ... What steps should you consider when a tree falls on your car?
Will landlord's home insurance pay for tree that fell on my car?
www.insure.com > Ask the Home Insurance Expert
Jun 4, 2014 - If a storm causes a tree at your rental property to fall on your car, don't expect ... Will landlord's home insurance pay for tree that fell on my car during a storm? ... The landlord, thus, won't be found liable by the insurance company and ...damaged if you also knew of the tree's fragile condition and parked by it.
Responsibility for damage caused by falling trees is a ...
www.post-gazette.com/...falling-trees.../2012112...
Pittsburgh Post?GazetteNov 23, 2012 - Pittsburgh Then & Now ... The philosophers wanted to know what happens when a tree falls in a forest. ... and knock branches onto your home, causing serious damage." Coverage ... But if you do the same to your own property, your own auto policy probably won't cover damages to your trees and shrubs.
DOT hits tree, tree branch damages legally parked car ...
Jan 25, 2016 | Cars & Trucks
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
Power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My TX is about 14 year old. The picture alwasy was excellent until we had an exlectrical storm that knocked out the cable box to the TV. With a new cable box the TV works. The picture has excellent color,...
Try your cable box on a different tv set and also try connecting the cable directly into the t.v, if that makes no difference then your tv set may have a power supply problem that was caused by an a.c line surge during that storm.
Oct 31, 2009 | RCA F19253BC TV
My zenith big screen tv won't come on model pvr5263dt
Hi
Thanks for using FixYa. This might have happened due to over-voltage. Please check the power supply unit for swollen capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. This issue might have occurred due to blown pico fuses located on the D-Board or due to blown fuse on the power supply board.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Sep 22, 2009 | Televison & Video
I received a reply but not about the TV model I described
check ac voltages at heater point of crt if present then check contineuty betn heater pinsif thete is no contineuty at heater then crt is faulty
Jun 15, 2009 | Philips Televison & Video
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
