If it sparks when plugged in that means the main fuse in the tv is not blown. If there was sorting wrong with the tv and you saw sparks the fuse should blow. If the fuse blew you will not see sparks anymore and the set will not come on. But if the fuse did not blow one of the following can be the cause.
1. A short in the line cord, check you plug and wire to make sure there are no breaks in the wire.
2. Sparking can be from a bad outlet, a plug that is not making good connection can cause sparking, try plugging in to another outlet if it still sparks check the prongs and make sure they are not blackened.
