Question about Yamaha HTR-6130 Receiver
How do you adjust the bass levels on a Yamaha HTR6130 receiver? I can get the display to show Bass 0db, but what button changes the settings?
    Problem Solver:
  • 6 Answers
When you touch tone button on your front panel repeatedly, you will get two option for setting bass and trebble, when you select Bass immediatly press your updown Sound field Program Button.
Please note:for better sound if your using Small front speaker keep bass to 0db and select the low frequency through sub woofer and program manually LFE from only Sub woofer and addjust CUT off frequency of Subwoofer to 160 and incase if your bass is not clear put it into rev mode.
Posted on Oct 27, 2009
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Jun 02, 2011 | Car Audio & Video
Need to know how to adjust bass, treble, fade, etc. on Alpine model CDA-7862
Press the MODE knob to choose between bass, treble, balance, or fade.
Turn the MODE knob to change each setting as it is displayed.
Mar 15, 2011 | Car Audio & Video
Lost my remote how to adjust my bass and treble levels from the front of the reciever
Hello,i hate to be the bearer of bad news but to change almost everything on that model you need the remote,including channel levels ,bass and treble etc...
Feb 11, 2011 | Sony STR-DG600 Receiver
I can't get any real bass out of this unit. Iv'e gone thru the manual 20 times and I set the "DZE" off, then adjust the bass to max and it made a little difference. But this unit is suposed to...
Try to exchange one speaker connections only, unplug connector from speaker and put them + to - and - to + pins.
In my opinion, both speakers are giving out of phase sound that cancels the bass sound, speaker connections should be same phase to get bass sound so just change connecting two wires at any one speaker, that will work.
Thanks.
Nov 26, 2010 | Clarion DXZ785USB Car CD/ MP3 Player
How to ajust amplifiers (car audio)
MOST OF THE TIME U WANT UR AMP RUNNING UR SUBS TO MAKE THE SUBS SOUND REALLY DEEP AND HITE REALLY HARD BUT BE CARFULL WITH THE BASS BOOST IT CAN BE TO HIGH AND CAN BLOW UR SUBS, NOW WITH UR AMP RUNNING UR MIDS U DONT WANT A LOT OF BASS MAYBE NOT AT ALL CAUSE UR SUBS WILL HANDLE THAT, SO U WANT A LOT OF TREBLE WHICH SHOULD BE THE LPF, O AND ANY WHERE FROM 6DB-12DB WILL BE GOOD.
Jun 16, 2009 | Car Audio & Video
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
Can I use front preouts for subwoofer?
First, you have to have a self-powered subwoofer (or two) with this reciver. That means the sub has its own amplifier. These are usually capable of accepting either Line Level (RCA) input or direct L and R amplifier channel speaker wires from your receiver from which it will react only to frequencies in its range. It doesn't actually use any if the power from your receiver's amp.
That is why you can extend your front speakers from the sub. Again, understand this - it is not playing any part in amplifying them. The amps in your receiver are just passing through it.
Setting your speaker 'Type' definition to Large will tell your receiver that they are capable of real bass (as opposed to small satellites) but won't necessarily steal anything from the subs. Set your LFE/Bass Out setting to Both if your front speakers are capable of handling real bass. Why would you want to deny them bass if they can handle it?
This part is confusing "If I can get the sub working on taking the lows out of the front speakers if I set them to large on the receiver then that is one thing less to send to the other sub on the LFE channel". The crossover feature allows you to define what bass goes to the sub. You would use the various points to smooth out the transition between your sub and the rest. Your quote of 47hz spec for something doesn't suggest your other speakers are great bass reproducers. One needs to see the +- db spec with less than x% distortion for that number make any sense.
Your receiver has two RCA Subwoofer Outputs but I'm sure they get the exact same level. If you're having trouble matching two different subs doesn't at least one of them have an adjustment for volume? Or maybe you could use physical positioning to adjust their comparative volume.
May 08, 2009 | Yamaha RX-V663 Receiver
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Aug 10, 2007 | Alpine CDM-7861 CD Player
Yamaha HTR-6130 Receiver Logo
633 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
