Question about LG Televison & Video
Lip sinc is off on my LG 47inch led 47LH90 with my FIOS when using a HDMI reg cable and I tried a 1.3b also. When I use the 3 wire plug in it is fine. The lip sinc is only a little off. any fixes? (my surround sound system is in sinc.)
  • jerry_reeve Oct 06, 2009
    LG is sending someone out to up date the software. (they said it just came out 2 weeks ago)
    Thank you,
    Jerry
LG is sending someone out to update the software. (they said the update just came out)
Thanks
Posted on Oct 06, 2009
Testimonial: "Thank you"
Picture flashes 5 or 6 times when changing channels on LG 4k. Using 2.0 HDMI cable from Fios set top box to Integra 60.5 pre/pro and out to TV. Works fine if I bypass processor and go direct to TV
Try to check with any other HDMI input of the Integra to input the set top box. Even if facing the same problem then you have to check both the the HDMI cable. Better replace it. Always remember that do not plug or remove the HDMI cable when the system are ON. Yo have to turn off before making any connection.
www.electro-medical.blogspot.com
Oct 31, 2015 | LG Televison & Video
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
Partial black screen on mulitple (but not all) inputs on panasonic plasma tv
Sorry but it's time to shop for another tv the cost of repairing would cost almost as much as a new unit.
Mar 18, 2014 | Computers & Internet
Need help with what cables to use...
First make sure that both the monitor and the fios box have power cords (just to see if she took them away). If they do then the next step is will need a cable to hook your tv to your cable box. Most likely you were using an HDMI cable which on the ends of the cable have kind of a square head that is usually gold or silver in color. Then take one end and plug it into the fios box then the other into the tv. If there is no HDMI cable there might be a cable that has either 3 or 5 plugs on each end with certain colors. Just match the colors up on the box and the tv. If it is 3 plugs on each end then it is an av cable and that is the input you will have to select on the tv. 5 plugs and it is a composite cable and select that input. If it was the HDMI then choose that input. Hope this helps.
Jul 03, 2013 | Televison & Video
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Hi. I got an LED "LG LE5500"
You wil need to connect using a DVI to HDMI cable. You can get one for about 5$
http://www.amazon.com/DVI-HDMI-Cable-6ft-Male-Male/dp/B0002CZHN6
Just connect it and choose the HDMI input its plugged into(1/2/3). If there is nothing on the screen adjust the display resolution on your computer. If you are using 1080i then the resolution should 1920x1080
Apr 08, 2011 | Video Game Consoles & Games
How to use my Zenith VRB4215 VCR with my new LG
please refer to this picture: http://www.retrevo.com/r/375bh427/3/Connections+for+your+VCR#q=Zenith+VRB4215
Rather than use the method in the picture above you should use the audio L+R and video OUT on your VCR and connect these three to the color matching audio IN and video IN ports on your television. The colors are red, and white for audio and yellow for the video. If you do not own a cable like this simply pick one up at radio shack they will know exactly what you need. The pictured method will work also but the picture and sound quality will not be the best possible.
Remember you are sending data OUT from the VCR and IN to the TV
Oct 29, 2009 | LG 47LH90 47 in. HDTV LCD
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
78 people viewed this question
Computer Repairing
Computer Repairing
