Question about KitchenAid 24 in. KUDP02SRSS Stainless Steel Built-in Dishwasher
The top spinner on my dishwasher is not working but the bottom one is. I think the line is either clogged somewhere along the line or there is a bad connection somewhere so it isn't getting the pressure it needs. How can I find the problem?
3 Suggested Answers
  • 949 Answers
SOURCE: Top shelf not cleaning
Hi, the most likely cause of this is the sump is plugged under the screen area, I have put some instructions together to show how to clean out down there. let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on May 01, 2010
heatman101
  • 43501 Answers
SOURCE: Whirlpool Gold Dishwasher - GU2700XTSB The
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 20, 2011
Dishwasher will fill and empty but no water coming through the spinners
It would help if you provide the model number.
Usually the problem is with the wash distributor circuit. The water alternates between bottom and top spinners (wash arms). The distributor may be faulty assuming the arms are clean and you have checked this. Some models use the same pump for wash and drain using impeller. In that case the problem could be the impeller is clogged and not allowing water to get in the arms. See this diagram.
Model number will help identify the part.
Dec 29, 2012 | Hotpoint Dishwashers
You wil have to excuse my lack of knowledge. I am not getting an error code so I don't know what the problem is. The washer has 3 spinners. The top and bottom spinner are spraying water fine, the middle...
Take out the top rack and inspect the pipe nipple that the rack slides onto. Make sure that there isn't any debris stuck in it. Next pull the wash arm in question off (it just pulls off) check for debris (toothpicks are the biggest culprits and food particles (sometimes glass so be careful). You should find something in there. The wash pipe goes from the bottom to the top of the unit, if the bottom one works and the top one works then your clog HAS to be in the middle wash arm. The water clearly makes from point A to point C so C has to have an obstruction or the wash arm is sticking and not spinning freely. Try to spin it my have but really inspect it for debris. Good Luck.
Feb 15, 2011 | Samsung DMR57LF Builtin Dishwasher
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
Dishwasher
How to Buy
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Apr 28, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Hi, the dishwashers top rack dishes are not being cleaned.. help?
sounds like the upper spinning arm is not turning check to see if it is clogged at the nozzles if so take off and clean particles out also check bottom ofjet that spray soap up to upper spinner and see that is not blocked
Nov 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Maytag model dwu9200aax pieces of plastic and cloth clog some of the rinse holes on the spinning rinse part..how to take apart rinse arm to clean it?
The top spinner part can simply be pulled off by grasping it near its hub and pulling downward. Push it back on and push in the locking clip in the center. The bottom spinner can be removed, First unscrew the center column. Hold the spinner with one hand, turn the base of the center column counter clockwise. Then lift column off. Then the spinner should lift off of the keyed white plastic base. Underneath it, on the neck off of which you lifted it, are two plastic washers that form a seal (supposedly). Good to clean these to make spinner rotate freely, but be careful not to break them taking them off. If you want to go farther in, there is the point of a strange shaped plastic nut sticking up into the base of the column. If you remove this, and the 6 torx screws holding the strainer cap, you can get it all out to clean it up (I had bits of plastic bag in the slots of a 4-armed thing that apparently sprays the filter screen), and scrub the washer in the bottom. Remarkably yucky down there in a 10 year old installation...
Nov 11, 2009 | Maytag MDB6650A Built-in Dishwasher
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Open Questions:
See all KitchenAid 24 in. KUDP02SRSS Stainless Steel Questions
KitchenAid 24 in. KUDP02SRSS Stainless Steel Built-in Dishwasher Logo
225 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
