Question about Maytag Dryers
Maytag dryer runs but will not heat - Maytag Dryers
  • Maytag Master
  • 7,482 Answers
Sounds like your problem is a faulty heating coil or thermostats.
Unplug the dryer.
Normally if you remove the back of the dryer, locate the air tube from the blower to the drum. The heating coil and thermostats are normally located inside of the air tube.
Remove the wires from the heating coil...Use a continuity meter across the two terminals and check to see that you get a reading of full continuity.
Good luck,
I hope this helps
Posted on Oct 05, 2009
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will run but not heat
More than likely you have lost your heating element.You can replace it yourself.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer runs, does not heat
check for continuity in the thermal fuse, also check heating element. make sure you have disconnected the power first. if this is a 220 volt machine make sure you are getting 220 to the machine. if one leg of the voltage has dropped out the motor will run but unit will not heat
Oct 05, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
53 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
