Question about KitchenAid Refrigerators
The freeazer is working but there is no cooling on the fridge up as the air is not circulating any more
  • 120 Answers
Check for vents open to the fridge area and adjust accordingly
Posted on Oct 05, 2009
MY FRIDGE ISNT GETTING COLD
Whilpool uses a fan at the back of the freezer to circulate air. If it burns out, the fridge will still cool, but not as well.
However, these don't usually burn out. What usually happens is that ice builds up and prevents air from circulating. If that is the case then you probably need a new bimetal temperature sensor on your cooling coils. This sensor sits at the back of the freezer (behind the wall) and tells the fridge when to defrost. If it doesn't then the ice will plug up the vents and may even stop the fan from working. Hope this helps.
Apr 15, 2014 | Whirlpool Refrigerators
Model WRT779REYMOO
Without more details as to how old it is and what kind of condition it is in, I would recommend you have it looked at by a refrigeration professional.
When a fridge is no longer cooling, the main culprits are clogs caused by frozen sections of the air circulation path, refrigerant leaks and faulty compressors. A professional technician can diagnose both. If the compressor is bad, refrigerant is not changing phases (which causes the cooling to occur). If there is a leak, there is not enough refrigerant to compress and the fridge will never cool.
Sometimes the fan is faulty, so the cold air will not circulate into the fridge.
Since your fridge has been sitting, you likely do not have any clogs caused by freezing. If your freezer side works but not the fridge, you either have dual compressors (and the fridge compressor is bad) or you have blockage in the air circulation path. There is also a very slim chance that the light inside your fridge is remaining on and generating heat.
Mar 02, 2014 | Whirlpool Refrigerators
Whirlpool refrigerator does not cool on refrigerator side. Freezer side works as it should.
most fridges have coils on the freezer side and circulate cold air to the fridge side. if the freezer is freezing, then the air circulation to fridge is not taking place. find the air ports and make sure they are not closed or blocked (they should be adjustable to vary fridge temp) and check the fan on the freezer side as it achieves circulation.
Apr 10, 2013 | Refrigerators
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Refrigerator and freezer not cooling
the relay on your compressor is more then likely the problem it is on the left of the compressor
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
50 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
