My screen has 4 rows of equally spaced lines running through it. could this be my graphics card.
  • 111 Answers
Yes, I can say without a doubt it is your video card. I have had that happen on multiple occasions. Replace the card and you are back up and running.
Posted on Jan 18, 2010
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
On start-up, the first screen with the Microsoft flag logo has a matrix of blue square dots (about 1/8" square in size) superimposed over the entire screen. Then, when the desktop appears, about half of...
go into your bios and make sure that video memory shadowing is dissabled, Sounds like a faulty video card or damaged signal cable. I would lean more to the faulty card though, try installing a new one as I would say thats your issue if your getting artifacts on the screen before the OS has fully loaded.
OFC you could try new drivers both for your chipset of *********** board and the graphics card in the interim.
Jun 22, 2010 | Dell Dimension 4600 PC Desktop
Vertical lines on startup. code 43 Adapter display. 8800GTS win 7
check to see your direct x status by typung dxdiag in run and test if they all pass then I would check the card wattage rating and you max power supply load the card may be to much for your power supply
Feb 02, 2010 | Leadtek GeForce® 8800 GTS, (320 MB) PCI...
Laggy saints row
Read this thread:
http://forums.steampowered.com/forums/showthread.php?t=854399
It laggs because the developers are idiots. They could not properly convert the game from Xbox to PC and they're not planning on fixing it.
Mar 28, 2009 | 2K Games Saints Row 2 for Windows
Graphics card
Then you probably need a new graphics card.. JTF requires these at a minimum to play:
Minimum System Specifications
  • Windows 2000/XP Home or Professional/x64
  • Intel Pentium 4 2 GHz or AMD Athlon XP 2000+
  • NVIDIA GeForce 4 (non-MX) or ATI Radeon 9500, DirectX 9.0c compliant videocard with 128 MB RAM
  • 512 MB RAM
  • 3 GB of uncompressed hard drive space
  • DirectX 9.0c compatible sound card
  • DirectX 9.0c (included)
  • 4x CD/DVD-ROM drive
  • Microsoft-compatible mouse and keyboard
  • 56 kbit/s dial-up modem for online play; 10 Mbit/s for LAN play
Oct 17, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Graphic card problem.
Your graphics card is bad. The reason you don't see it on your bios screen is because it is not displaying in the high resolution high color graphics. Once your card starts displaying high resolution high color, then you get the lines. You need to replace your graphics card.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Sis 6326, (4 MB) Graphic Card
Rows of Lines across top of screen
I decided not to repair, but use the 16:9 feature on the remote control.
a kind of letterbox look, not bad at all.
I'n not going to spend money, replacing the vertical output ic circuit's bad capacitor or vertical power supply for bad cap.
Jun 11, 2008 | Toshiba 24AF43 24" TV
Bluish screen -
is it a greenish blue?..... if so you have lost your red signal..... check your monitor connectors for bent or broken pins...... usually happens after swapping cables or monitors on a computer..... you could also have a bad cable or monitor..... is the monitor a CRT or a flat panel.... loss of one color is very common on CRT monitors, and could be a bad solder connection on the CRT driver board, or a bad video chip..... flat panel LCD monitors don't usually lose a color, although it is possible.... the most common failures on LCD flat panels is total power supply failure (no power at all) or display matrix driver failure (colored stripes across or down the screen), but a cable failure is also possible, like i said above, check the connectors for bent or broken pins..... there are 3 rows of pins...... at the widest side of the connector, there should be at least 3 pins next to each other on that row (sometimes there are 5), the middle row should at least have 3 consecutive pins as well (and again, there are sometimes 5) the last row (the smaller side of the connector) should have at least two (but sometimes all 5) pins in it. the first row and last row of pins should line up vertically, and the middle row is offset a half a space, so from top to bottom, the columns of pins make a zigzag...... if the connectors are alright, then your most likely problem is the monitor..... if another monitor works on the computer, it's the monitor..... if another monitor has the same problem on this computer, then it is the video card (or the motherboard's video output, which is fixable by installing a video card)
Jul 26, 2006 | MPC Computers Envision EN 5100e 15" Flat...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
