Question about Garmin StreetPilot C330 GPS Receiver
Well, Mom just bought a C330... and of course... I am 1300 miles away trying to help!
Hi.. thank you in advance.. in case i get knocked out! by my pc... that is! Could you please explain to me... how you charge "it"... Is the USB acting as a charger... (I think not) or does that just download info? I read that there is a rechargeable lith battery... does it come with the recharger? When you use it in the car.... the power would come from the cig lighter thang.... (duhh) ... If you could... PLEASE possibly explain.. that entire USB wire thing... because Mom wants to know.. should i turn it on... when I plug in to my PC??? So if it does not even charge from the PC.... I would like to come back to her... with ALL.. the info... ALL the answers.. if you can understand... what I am tawkin about!!! I appreciate any help... you can give me... helllllppppppp!!! I just visited her in FL couple weeks ago.. had to change the volume on her base of her cordless phone.. sooo loud... but... after 4 yrs... they did not know how to do it... I love 'em!! ty... Kat
  • 44 Answers
Hello, You can charge the unit using either the USB cable or the car adapter. You must install the USB driver software on your computer before connecting the USB cable to the PC. The USB cable is also used to update the software in the unit when Garmin provides it. The program installed with the CD will help you manage this. However the unit generally comes ready to go out of the box. Just use the car adapter and plug it in to the car. Good Luck! Dr. Know
Posted on Dec 23, 2007
Check engine light flashing, knocking, low power
Hello Shena: The flashing check engine light means to get your attention as the engine is misfiring as well as having some sort of "fault" The only reason that light comes on at all is that your vehicle is exceeding federal tailpipe emissions by a factor of 1 and a half.
The knocking and shaking is most likely caused by the misfire.
Have it analyzed by a good shop and best case scenario is there is a malfunctioning spark plug, spark plug wire or ignition coil. Get it done right away, misfires can damage the catylitic convertor (thus the flashing instead of steady light)
It would help to know the VIN of the car so mechanics can drill in on the specific model of your vehicle.
Norm <"}}}}><
Jan 26, 2014 | 2003 Kia Spectra
I just turned on my car after being out of town for a few days and it made a loud knocking sound and the service engine light is on. It has never made this sound before. It's not the weather.
alot of times when you let a car sit for a while, the oil will slowly drain down into the oil pan. When you start the engine, the knocking you hear is all the metal parts flying around, waiting for the oil pump to start spraying the oil everywhere. If you start it back up, let it run for a minute and listen for the noise to quieten down, it should eventually go away. You can help prevent the dry start as you are having by using good synthetic oil, and sometimes adding in LUCAS oil treatment.
Dec 30, 2011 | 2007 Mitsubishi Eclipse
2007 Honda CB 1300 ABS light stays on
Hi, Baz for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $10 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
abs light on dash
2007 ABS light issue warranty GL1800 Information Questions goldwingdocs com
CB1300 CB 1300 SHOP MANUAL CD ROM EXTRAS IMPROVED Great Disc eBay $10
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB1300 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 13, 2011 | 2006 Honda CB 1300
89 gmc c2500 5.7 tbi had oil changed at well known franchise place. They also recommended flush out, let run 15 min with stuff he put in oil. Then drained, added oil and was about 1/2 mile away when motor...
Hi, this is not the first time i've heard of this problem..I have repaired engines with rod knock, crank bearing knock and piston slap after these treatments. These products can clean so much carbon and varnish from the engine that it brings the real internal problems to the surface. Try using thicker oil
Jul 25, 2011 | 1985 GMC C2500
I have a 2006 Honda VTX 1300 Retro Cruiser and bought it used with 2300 miles on it. Of course, the previous owner said he had no problems with it, and I can believe him because we have been friends for...
Try adjusting the steering neck bearings. They should have been tightened at the 600 mile check up, but most mechanics short cut and skip the adjustment. Take off the handle bars and the upper triple clamp and tighten the "steering stem nut"/"neck bearings" almost to binding, then back it off a tiny bit. You may want to run your tire pressure around 34-34 PSI to help get more even tire wear.
Jul 13, 2011 | Honda VFR 800 Interceptor ABS Motorcycles
SONY bdp s360 wont play from the menu screen
Could be as simple as a fingerprint or smudge.Give the disk a good wipe with a cloth like the ones for cleaning spectacles and retry.
Jan 16, 2010 | Sony BDP-S360 DVD Player
Quiet knocking under the hood
SOUNDS LIKE A ROD KNOCK..ON THE BOTTOM END ... CHANGE THE OIL AND CHECK ITS CONDITION... SOUNDS LIKE U MAY HAVE A CAR WITH SOME MILES ON IT... TRY AN ADDITIVE OR USEING A THICKER OIL ..
Apr 09, 2009 | 2005 Chevrolet Equinox
Digilife ddv-c330 instruction/operator manual
Hi, have lost my digilife ddv-c330 cd & i wanna u the cam as my webcam, how can i get the drivers?
Jun 30, 2008 | DigiLife DDV-C330 Digital Camera
Lost with Garmin c330
Have you tried re-loading the current software? If that doesn't help, you may need to purchase updated maps.
Jan 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
50 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
