Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic PT53WX42 dead with 5 blnks of power LED
I have this Panasonic PT 53WX42 which is totally dead.When you first power on the relay clicks but nothing further. The power LED flashes five times sequentially.
Nothing inside seems burnt or open short circuited.
I am a professional repairer. Any help would be appreciated.
  • Samir  Shah
    Samir Shah Oct 14, 2009
    Hi I have checked the convergence IC's you mention and also checked all the associated resistors,No Luck all check out Ok.
    5 blinks is an uncommon error I am told,Convergence or short normally results in 3 blinks I am told.
    Please help.
    Samir
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
This is a common failure for this particular television. The power light might be blinking indicate a short in the power supply
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 05, 2009
Power would not stay on red led flashes
I do not think we will get a response from person asking but you are correct, number of blinks indicates where problem is, the two most common are either a sequence of 3 blinks or one of 5 blinks.
Hard to help unless blink count is known.
SD TECH
Oct 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
Power for 5 seconds, then out 1 blink on led 140 circuit?, what is it, and how to replace it
STK ICs replace Both of them big black ICs example
STK392-110 Call Mats 1-800-628-1118 You must know How to solder in order to repair.
Dec 15, 2009 | Panasonic PT-53WX42 53" Rear Projection...
How to get into service menu
I just Posted this For another person wanting same infor. If you cannot find it on search let me know and i will post it to you. Its alot of typing.(9) Steps plus other steps also after you aline convergence make sure you Save them Last step or you will have to start all over again.
Dec 24, 2008 | Panasonic PT-53WX42 53" Rear Projection...
RESISTORS
The value of those resistors is 0.27 ohms 5% 1 watt.
Click here to find the resistors.
Jul 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT53wx42
You can go the the following link they have access to remanufactured boards just leave them a email with your model and tell them your needing the signal board, and they will respond quickly.
http://servicemanuals.vstore.ca/
Jun 23, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Shutting down....
You have POWER supply board that went out.....apparently this is a common thing for this model.....sorry to see such low activity on this site......hope it helps.....
Apr 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
53"panasonic television
UPON POWERING UP, MONITOR STAYS ON FOR APPROXIMATELY 5-7 SECONDS, THEN POWERS OFF. RED LED FLASHES 3 TIMES..PAUSES...THEN FLASHES AGAIN 3 SECS.
Jan 31, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 53wx42, no power, Blinking LED
Have you gotten any solutions to this problem? We had the same thing happen to our TV recently. Haha, maybe they all died on the same day. Before this, we had a convergence problem with the blue color. If you had it fixed, how much did it cost? Our warranty just expired too! Thanks
Aug 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
166 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
