Question about Garden
I cannot get it started ! Krachner Power Washer
I cannot get it started ! I would like to print off a manual since I didn't get one with my new washer.
  • Ronald Park
    Ronald Park May 11, 2010
    Need to know make and model to try to help you out.
2 Suggested Answers
Jmonica1
SOURCE: New 75219 Power Washer is missing owners manual.
Any luck finding someone to give you a copy of the manual for this model? I bought one on clearance and it doesn't have the manual and I'm scared to even start it up without reading the manual as I don't want to mess anything up upon first start. If I ever do find one, I will post a copy of it for you. Good Luck! Thanks
Jim
Posted on Jun 10, 2010
Instructions are in french
You can print of a manual for it online, Just go onto google,There are sights where you can do it free of charge. I have done it lots of times, When i bought used (Audio) Equipment, End the people didn,t have the manuals for it.
Oct 08, 2012 | Televison & Video
Tip
I replaced the valve prematurely! Check the power to the valve FIRST! My had no...
Your washing machine will not fill up with water. You have checked the hoses, cleaned the screens, and still no water. Now what is next?
First make sure that you unplug the washer to prevent a shock. Then you will have to get to the valve. For some washer this can be done by an opening in the back panel. And for other you may have to remove the entire top of the washer to access the valve body.
Hopefully you can get there without removing the wiring, so that you can check to see if you are getting power to the valves. Once you can get to the valve body, then carefully get a meter on the connection to the coils, then plug in the washer and start the cycle where the water would normally flow. If you have power at the coil and the water does not flow then you know that the coil is bad or the valve is stuck. There are ways to clean the valves but usually a new valve body will be under $40.00 and it is not worth the mess and the possibility that the valve will soon get stuck again. If you find the problem there, just replace the valve, it is much easier.
If you are getting no power to your valve then you know to look back in the wiring further. You may have a bad switch in the timer. Follow the wires and trace the back to see where the power is stopping at. If you have power going to the timer and no power coming out then you have found your problem there.
Troubleshooting appliances is often just a matter of following the problem back to where it starts. Be patient and be very careful when working with electricity. Always make sure you have the appliance unplugged when you are not actually checking for voltage. Also be aware that some appliances have power on what you would think to be the neutral.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
on Jul 04, 2011 | Washing Machines
MANUAL FOR HEALTH O METER MODEL BFM689SPKH-63
I called their comsuner number for this scale, BFM689SPKH-63. the number was 1800 672 562. She helped me calibrarte the scale, but that didn't work. To calibrate, step on and off 6 times, let it power off, then try again. That didn't work for me so she said to mail it in to their place in MO, and they will send me a new one. So give that a shot.
Jan 28, 2012 | Health-O-Meter Health & Beauty
My wtw6400sw3 didn't come with owners manual (
goto whirlpool.com, then click on manuals and literature, type in model, download pdf file. its free
Jan 25, 2012 | Whirlpool Washing Machines
Faint grey printing
According to the service manual for problems with light print image, the cause can be the Developers or High Voltage Power Supply (HVPS). Other possible causes are given as: Developer roller is stained when the toner or developer cartridge is almost consumed. Ambient temperature is below 10 degrees Centigrade. Bad contacts with the HVPS or abnormal output from the HVPS. To replace the Developers you would need to purchase a replacement Imaging Kit CLP-R300A. Any problems in the HVPS would require a factory repair.
Dec 13, 2011 | Samsung CLP 300 Laser Printer
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
DDR30E operating instructions, need to know how to run unit? New unit didn't get instruction manual
The following link is to your Owner's Manual. You can download and print it for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR25E__DDR30E__DDR45E__DDR5011_manual_v3.pdf
Hope this helps you. Please let me know. Thanks.
Jul 02, 2011 | Danby Dehumidifiers
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer has a LE (or EE) code or something like that. First character looks like an E missing the top bar, or an L with an extra bar in the middle. i was doing a load of towels when this happened. i assumed...
Washing machine has an LE error code
Is this a new installation? In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jun 09, 2011 | LG Washing Machines
Lost instruction manual on how to start fitzroy heater 12mths old can you help !
Seems your Cannon Fitzroy heater is unique to Australia & New Zealand. But, according to reports, is not known for it's reliability. In any event, there are several models of this heater and you didn't mention which one you have. So, I have included a link to a site that list all the Fitzroy Models. Find the one that matches yours, click on the link and you can download and print the Owners Manual.
http://www.sampfordixl.com.au/cannon/manuals.html
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | Heating & Cooling
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
