Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
WND3300 Wireless router on the fritz? I can't connect to internet even though I am sending and receiving signals. My desktop will only connect when router is disconnected and it is plugged directly into the modem. How can I fix this? Can I reset without the CD...can't seem to find the box?
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 05, 2009
How to turn on bluetooth radio
Which operating system ???...
There are a variety of ways to connect to the Internet or a home/business network using your Hewlett-Packard (HP) desktop computer---via a modem, Ethernet cable and even wirelessly.
A wireless connection works by sending a signal from your modem or router to your HP desktop's built-in wireless radio.
The radio receives and processes the signal so you can access the Internet or a home or business network.
In order for the signal to be received by your HP desktop, you must enable the wireless radio within the computer's configuration.
Click "Start," "Control Panel."
Double-click on the "HP Wireless Assistant" icon.
The HP Wireless Assistant dialog box will open.
Click the "Turn On" button next to the words "Wireless LAN."
Click "Close" to activate the wireless radio.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00045315&product=12455 - DeviceEnabled
Using Bluetooth Devices (Windows XP)
http://h20239.www2.hp.com/techcenter/wireless/wireless_TS.htm
Wireless networking center
Aug 30, 2013 | Packard Bell Computers & Internet
Do I need a USB adapter to connect to a wireless network?
You need a wireless card. It could internal or external as a USB device.
May 20, 2013 | eMachines T5048 PC Desktop
Hello , I have AT&T internet , and i sign to the internet using a wireless router , the issue i can not get my i phone to connect to the network even though it detect the wireless signal and i sign...
Can you indicate the model of your phone? And do you have any other computers/gadgets that connects to the wifi? Because if you do, you need to focus on the phone and try not to mess up w/ the router yet . Perhaps tyr to "forget the network" and reconnect back. if this diesnt work you can chage wireless seurity settings or add the IP addreess manually.
Dec 18, 2012 | NetGear WGR614 Wireless Router
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
Weak or NO signal to MN-500 Wireless Base Station
Have you tried upgrading the firmware - http://www.tomshardware.co.uk/forum/page-7797_17_0.html
Jan 25, 2009 | Microsoft Broadband Networking MN-500...
My wireless G is properly installed but cannot find the internet
I have this problem before. I think I rebooted my pc but first make sure you have the firewalls turned off from windows and your security suite.
Nov 19, 2008 | Computers & Internet
No internet with wireless laptop
Check to be sure that your network connections are set to automatic(control panel->network connections then right click on your wireless connection go to properties- tcp/ip click on that and check there.
Oct 29, 2008 | Linksys Wireless-G Broadband Router
My Aspire 5570Z will not connect to the wireless router even though it shows it's receiving a full signal.
FixYa,
Thanks some how it started working. What ever I did prior to sending the e-mail for help worked. Thanks anyway.
Aug 23, 2008 | Computers & Internet
SMC 11n Router: wireless set-up
Hi there!
Do you know how to check the wireless IP address at your iBook?
May 04, 2008 | Computers & Internet
Disconnects while working.
it may be as simple as the wireless connection signal strength, as doors, solid walls or any solid object that is in it's line will cause the signal to be very low, and at that point it will disconect from the internet as it is unable to send packets of information to your wireless card from the router. You can try your router in another telephone point that is nearer the pc to see if the connection drops, or use a different channel number which can be changed in the routers settings and the wireless cards properties as interference from other electrical appliances on the MHZ level can cause signal loss. Laptops tend to suffer less with the signal loss because they normally have a signal booster in the screen of the laptop within the wireless receiver ariel.
May 08, 2007 | Belkin (F5D7000) 802.11g/b Wireless...
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
789 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
