Question about HP Photosmart 2710 All-In-One InkJet Printer
I have put in ink cartridge and printer just keeps saying insert black or photo print cartridge in right stall. It won't let me copy anything, but I can print.
Cleaned with Q tip and alcohol the area behind where cartridge goes.
Posted on Oct 08, 2009
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
I just put all new ink in my printer and will not print. Unplugged it to re-boot it, still won't work. If i copy something by hand will not print, if i copy something from computer it does not...
be sure that you remove the tape from the cartridges before you insert it in the printer, it has a color pink attach to the tape remove it slowly then insert the cartridge to the printer,
Aug 03, 2011 | Computers & Internet
Canon MP140 fails to print
I don't think that has anything to do with reaching the board of 5000 copies. Your cartridges have no chips on them or anything. You might actually have a problem with your black ink cartridge, as the printer is telling you. Remove the black cartridge, gently wipe the contacts with a dry cloth and put it back in. Hold the "resume" button (triangle in circle) for about 10 seconds to try and reset your cartridge. If none of that works, I suggest you buy a new black ink cartridge.
Apr 07, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Printer says to insert black print cartridge in right stall
Refer to printer manual as some of them require you to reset the software to accept new cartridge.
Manual here if you do not have one
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Dec 03, 2009 | HP Officejet 7210 All-In-One InkJet...
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
My printer does not recognise my ink cartridge?
If it is not a Dell ink cartridge, it won't work. Dell has it to where you have to buy their cartridge.
Jan 21, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Print Cartridge in Right Stall not Supported.
    print cartridge colour ink is not workink fix with hp print
    May 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
    HP Photosmart 2710 All-In-One InkJet Printer Logo
    165 people viewed this question
    Seeker5211
    Seeker5211
