Question about IBM POWER SUPPLY 120W 25P4966 Power Supply
My monitor go to "standby" and i can't get it on again for a few minutes if i change resolution (starting an old game) or restarting my monitor. In the "standby mode" the light is yellow, but blinking.
  • anders_lerbe Oct 05, 2009
    How do i delete this? I put it out once more with the right product...
  • 416 Answers
this is because the game is changing the resolution and frequency of the video card to make it compatible with the software the game uses to run. The easiest way around this is to attach a different monitor long enough to change the settings within the game after it loads up. Find a configuration that works when u switch to the other monitor and you will be good to go. Dont worry, ive had this problem before too and there is nothing wrong with your monitor. an easy way is to go to the display options in windows and view the current resolution and frequency and try to match those with the game, but i can be sure from the nature of this question that you have your resolution set too high for the card to automatically render the video, your gonna have to cut way back to your lowest resolution and it should at least start up long enough to make adjustments and these adjustments will be permanent until you personally revert the setting. Good Luck And Please Rate This Post!!!!!
Posted on Oct 05, 2009
Monitor work well on starting, but entering into any games, its turn black and the power light is on. Computer has nothing problems with other monitors.
The games try to start a display mode (resolution) with which the monitor is not compatible. Some monitors are very tolerant and try to display whatever they are hit with, even if the picture is poor, at least you have an option to change the resolution to a different one. Some however are very picky and just go into standby if they are fed with signal that's not optimum.
You have to find out which display modes your monitor does support and then try and configure the games to use one of those supported resolutions. If you can borrow a more tolerant monitor you could attach it temporarily, open each game and adjust the configuration to satisfy your whimsical monitor, and then reconnect it.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 26, 2011 | Computers & Internet
Hi, My monitor has dull display. After starting my computer, I could see the desktop but after few seconds it disappears. I am sure whats happening. Please suggest me what to do.
My answer will help Windows XP and Windows 7 users.
When the computer starts, start pressing F8 button. After several seconds you will see the following menu.
Safe Mode Safe Mode with Networking Safe Mode with Command Prompt ---------------------------- ---------------------------- ----------------------------
If you have Win XP, there will be a menu item as 'Enable VGA Mode'. In Win 7 you will see 'Enable low-resolution video (640 x 480)'
Select this option and press enter. (XP users will have to enter again).
After the computer is ready, goto display properties and save the resolution.
- In XP right-click on desktop, select 'Properties', Click the 'Settings' tab (last tab on top), and click 'OK' button.
- In Win 7, Right-click on screen and select 'Screen Resolution'. Click 'OK' button.
(Ignore any warnings)
Restart the computer.
Set the screen resolution again to a reasonable setting.
- Be careful! If you set it too high (if the monitor does not support the resolution you select), again the screen might disappear! (Sometimes this happen automatically after installing a game)
Jul 19, 2011 | Dell E176FPC Monitor
"Not Optimum Mode","Recommanded Mode 1280
FIXED : Before you start your legacy game, software where the "Recommanded Mode 1280 x 1024 60Hz" keeps showing, change your display FROM VIDEO CARD DISPLAY control application to 1024x768 or your choice.
My Syncmaster 2233 had same problem of "Not optimum mode" box coming on whenever I started any old game like Age of Empires etc. It got fixed by selecting FROM DISPLAY CARD DRIVER CONTROL UTILITY's (mine from Catalyst Control Center) >Set desktop area to > 1024 x 768 in my case BEFORE STARTING old application/game. Switch back to your normal resolution after you are done with this application.
Hope this helps.
Regards
Saurabh
Jun 29, 2011 | Computers & Internet
When i start playing certain games, my monitor suddenly says no signal and turns black. However, i could still hear the music of the game in the background yet can't control a thing. When i perform a...
It has something to do with your screen resolution. Maybe the games resolution is higher that what your monitor can use. Under your game settings, look for Options> Video> Resoltion, set it to 800x600 and try to play again. If it works, then adjust it to a higher resolution.
Cheers,
Feb 14, 2011 | Computers & Internet
When I turn the monitor and computer on, the monitor will come on for just a few minutes and then go to a full black screen and will not come on again. I have bought a new cord to go from the monitor to...
Have you tried to start the computer up in safe mode and then change the display resolution check cords power cord on the monitor the specs say 1,280 x 1,024 resolution
Feb 13, 2011 | HP Pavilion F1703 17" LCD Monitor
Like a lot of others. Black screen after 3 secs . Switch off, restart, a few secs off again any ideas ????
Your computer's video adapter may be asking for a resolution that is not supported by the monitor.
Start up in Safe Mode (Google it if you don't know what this is)
Change your display resolution to a low setting like 800x600.
Restart the computer and let it start up in Normal Mode.
The monitor should work now and you can change to a higher resolution so long as it is supported by the monitor.
Apr 17, 2010 | Computers & Internet
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Video problem
I had this same problem. What worked for me was going into safe mode, and in there I removed the video card from the device manager. When I restarted normally & windows re-installed it I was set back to the 800 X 600 which seems to be the default.
If that does not work I guess you could fall back to the old standby of delete windows & reinstall. While not my 1st choice it would fix the problem. Or another thought is take the machine to someone that has a better monitor, load into windows set it back to 800 X 600 & shut down. Back home it should be set again.
May 29, 2008 | ASUS P4S800-MX Motherboard
LCD problems... Can you help me?
it has nothing to do with your computer, if you put the monitor on a different computer it will do the same thing. the message comes directly from the monitor itself. you have to keep your screen resolution at 1280 x 1024
Mar 23, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Computers & Internet Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
