Question about Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger
I have a 200 lc hitachi excavator replaced starter 3 weeks ago now machine is clicking the cylanoid beside the batterys and wont roll over
    Scholar:
  • 73 Answers
Check battery connections at the terminals and at the ground point poor connections will kill starters and Oh so much more good luck
Posted on Oct 17, 2009
If 75 landy Hitachi track hole. My swing motor,manifold union center is leaking. I would like to know how to fix it myself. Or how much it would cost to have someone to fix for me.
Hitachi Deere Excavator Center Joint / Rotary Manifold ...
? 10:00
https://www.youtube.com/watch?v=Vsd_Os6WFCw
Mar 12, 2013 - Uploaded by woodieswood
Hitachi Deere Excavator Center Joint / Rotary Manifold Rebuild ... my Hitachi landy swing brake keeps ...
Viewing a thread - Hitachi Excavator- Swing motor gearbox leak ...
talk.newagtalk.com/forums/thread-view.asp?tid=362837...flat...1
Jan 30, 2013 - 3 posts - ‎3 authors
Hitachi Excavator- Swing motor gearbox leak ... 10000 hrs that I am thinking the seal on the swing motor reduction gearbox went out. ... but a friend that works on construction equipment said to check the swivel manifold.
Dec 08, 2015 | Cars & Trucks
How do i go about finding a service manaul for my Hitachi EX60Mini Excavator? I was told it was a grey market machine by the dealer.
go DownloadAManual.net and there is a manual listed for hitachi ex60-3 excavator service manual download
The dealer may be saying that it is a japan machine made under licence in china and is not covered by the hitachi warranty properly and because of that dealers are reluctant to work on them as they are considered inferior product
Oct 13, 2015 | Hitachi Televison & Video
Replaced ignition switch, key, battery and now car wont start after running then it will start up hours later..is it the starter?
When key is turned the starter is energized by a solenoid that applies power directly from the battery to the starter. Any loose connection will prevent the starter from turning over. The solenoid can also have burnt spots on the contacts inside case that will prevent current from getting to the starter. A click noise is the solenoid energizing so
if all connections are tight and the battery is good the only
other problem is the starter may be bad. Brushes on the
starter may have seen their life ended. this is usually identified by tapping on starter with a hammer while trying to start engine. If starter spins, replacement is needed.
Feb 06, 2018 | 2000 Saturn SL
Battery wont stay charged
Its got a drain somewhere can you find the sound?
Nov 26, 2013 | 1993 Subaru Loyale
1996 nissan maxima is eating cylanoid switches
If "tapping" the SOLENOID ever worked... you
HAVE A DEFECTIVE SOLENOID.
Defective is all inclusive... and when "STUFF"
happens (burns up)... it is VERY LIKELY to cause
COLATERAL damage...
(FRIED WIRES & IGNITION SWITCH)
((fix that "STUFF" later)).
At the SOLENOID ... apply "B" battery DIRECTLY
to the "S" terminal of the SOLENOID...
IF it does not fully spin up the starter 100% of the time
the solenoid or the starter is DEFECTIVE.
Apr 14, 2017 | 1996 Nissan Maxima
Wont turn over
The starter is most likely the problem,tap on the starter lightly with a hammer while trying to start the engine,dont get run over doing this it will take two people,if the engine starts,the starter needs replacing.
Apr 25, 2010 | 1998 Jeep Wrangler
Starting issues,
have your battery check first.ive never seen a battery that will last for 5 years.shelf life starts as soon as the acid is added to the battery.
Jan 20, 2010 | 1991 Ford LTD Crown Victoria
I hae a 97 f-150 4x4 the starter wont work
Have your battery load tested first. If the battery is good then check the current draw on the starter. If the starter is pulling over 400 amps it is cooked and needs to be replaced. You might also the starter bendix before replacing the whole starter.
Mar 03, 2009 | 2004 Ford F150
1997 Plymouth Grand Voyager won't start
there is a starter relay in the relay box. check for power going to the relay box , also have your check for voltage going to the starter . check for ing feed at the small wire also . before replacing any more parts , i would think that all off this was done the frist time?
Dec 18, 2008 | 1996 Plymouth Voyager
Starter
the most common problem would be the starter relay,
the contacts burn out so just replace the relay.
cheers
Jun 30, 2008 | 1984 Nissan 300ZX
Heavy Duty Associated Equipment 6002B 6/12/18/24 Volt Heavy-Duty Battery Charger Logo
346 people viewed this question
Top Heavy Duty Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Heavy Duty Electrical Supply Expert? Answer questions, earn points and help others
