Question about RCA HD56W66 56" HDTV
RCA HD56W66 a fall down stairs ended up splashing a small amount of water down back of set....now covergence is off and screen bends as if pushed in middle...no picture or sound. Any suggestions?
  • 2 more comments
  • kjathena Dec 23, 2007
    is this self repairable ?
  • Anonymous Apr 14, 2008
    hav double image on screen picture
  • latasha Apr 15, 2008
    convergence is off double picture screen bends
  • weekend Sep 06, 2008
    my convergence does not even show up on my setup menu anymore!! High price to fix triple image on my screen
    Genius:
  • 1,153 Answers
Sounds like pincushion and convergence problems
Posted on Dec 23, 2007
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
What is the proper way to use a hand truck to mount a curb or a small change in elevation?
By walking backwards, pulling the handtruck, not pushing it. This is also true for climbing stairs. You walk forward to go down a curb.
Feb 09, 2010 | Hand Tools
Rca hd56w66 no power not even the green light power board looks good suggestions to find the problem?
Check the fuse. Its located on the right side looking in the rear of the TV its the small board where the power cord plugs into. The fuse is on that board.
Jan 01, 2010 | RCA HD56W66 56" HDTV
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
Firmware upgrade
firmware upgrade? i am not aware you can ungrade the firmware on this set this is a rca itc222 chasis. there is service software that allows you to diagnose problems. rca offers no firmware update for this set
Dec 18, 2007 | RCA HD56W66 56" HDTV
Moving Information
Poczekaj, not a good idea to break it down, screen assembly is veery fragile when not installed into the set, best thing to do is rent a refridgerator type dolly, wrap the front of the set with blankets and then put the dolly under the side of the tv, winch up the strap and with 2 people walk it up the stairs, one pulling the dolly the other person at the other end to push upwards, slow and easy and you`ll have no problem, if hauling in a pick-up it MUST be winched down to the bed or it will fall, (been there done that :) hope this is what you needed, more questions? feel free to e-mail me back, Happy Holidays, BMW Rider
Dec 10, 2007 | Mitsubishi WS-65809 65" Rear Projection...
HD52W66
The Model # is wrong it Must be HD52W67 0r HD56W66. Set is going to shut down, unfortunately the trouble to me in many different areas you need to call an authorized RCA repair shop and have the unit trouble shot.
                                      Packman
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Covergence problem
press and hold menu then push power then volume.
Aug 17, 2007 | RCA HD56W66 56" HDTV
RCA HD56W66 56" HDTV Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
