Question about Hotpoint RB757 Electric Kitchen Range
COIL FROM THE OVEN STARTED SPARKING AND SIZZLING
  • 120 Answers
Discontinue use of that element immediately and remove and discard when cool. Go to a parts place and replace with appropriate part. The element is worn out and is unusable.
Posted on Oct 05, 2009
How do I replace the bottom oven element on my Maytag CWE5800?
This shouldn't be too difficult. Make sure the power is off. Remove the screws that hold the oven element in place. carefully pull the element out from the back wall without losing the wires back in the holes. Install the wire on the new element push it back in the wall. Reinstall the screws and you are set. Turn the power back on and check to make sure the oven cycles when it reaches the set temperature.
Feb 08, 2014 | Maytag Ovens
Sharp r-930ak microwave oven is sparking
A dirty or damaged wave guide cover can cause sparks, fire and noises. You can order a replacement wave guide cover from many appliance parts websites for less than $15 in many cases. It should fix the problem.
May 03, 2010 | Sharp R-930AK Convection/Microwave Oven
Self cleaning oven sparking and wont unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 11, 2010 | Frigidaire FEB27T5A Electric Double Oven
My 1990 maxima is sparking from the coil but is getting no spark otherwise
sparking from the coil when you crank it over and test it? replae the distributor cap and rotor.... did you have it apart before this problem started? is the rotor in correctly?
Sometimes you get carbon build up in the cap or on the rotor that causes the spark to go other places than where you want it.
Peace,
Mar 03, 2010 | 1990 Nissan Maxima
Gas oven - electric igniter - trips electric
you have cleaner inside the glow coil marrets and it is probably causing a short circuit and tripping breaker
Feb 06, 2010 | Ovens
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Hotpoint EG54P ignition sparking by itself
The reason it stopped was you need to push down to activate the switch and turn on the sparking be careful about getting water down in the unit ..Glad to Fix Ya plz rate my answer
Feb 23, 2008 | Ovens
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
Hotpoint RB757 Electric Kitchen Range Logo
392 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
