Question about Canon Pixma iP6000D InkJet Photo Printer
My printer has just stopped printing, like its running out of ink but the ink cartridges are full, does it need a new ribbon?
  • Bill Schilz
    Bill Schilz May 11, 2010
    Are you getting an error code on the printer screen?
  • 17 Answers
SOURCE: Won't print
not normally,try new paper. chook.
Posted on Mar 14, 2007
SOURCE: won't print with just black ink cartridge
A part solution is print/properties/maintenance/ink cartridge settings/select black only.
You do initially have to buy another color cartridge but you won'thave to buy another expensive color cartridge again in the future.
I
Posted on Jan 12, 2009
SOURCE: PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Posted on Feb 21, 2009
tstraub
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
  • 240 Answers
SOURCE: Canon MP210 Won't print Color - Color Ink Light blinking
try to run a maintenance page or to clean the printhead go to your printer panel and select maintenance..and print maintenance page ..or to wipe it on a wet cloth in order to avoid clogs..
Posted on May 18, 2009
Why does the black ink not print?
Try going to the maintenance screen and running the cleaner and any other adjustments that can be made from there.
Sep 28, 2014 | HP Photosmart 6520 e-All-in-One -...
I refilled the ink cartridges on my canon mp250 copier because it stoped printing. The little info box said that the ink was running low now it still won't print . I 've re inserted the ink cartridges...
originally, when u have ink cartridges in Canon product run low u need to buy new ones, because it was designed like that. even u have refilled the old cartridge full, it will detected low ink because the old cartridge already detected for the beginning. this designed to make Canon buyer to buy new ones ink cartridge. but, there some trick to make your old cartridge detected as new one, all u need just to reset the setting for cartridge recognition. try to visit this site:
http://resetcanon.com/reset-canon-mp250-pixma-inkjet-all-in-one-printer/
maybe this site can help your problem, regard riyan.
Mar 09, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My 5500 printer is printing blank pages - can you help?
Hi
Does the ink cartridges are new or old? How long did you stop printing? Because if you stop printing for a very long time, the ink dries up and you need a little cleaning for the print head. Remove the ink cartridges and rub the print head into a plain paper with alcohol until ink flows and the run the cleaning maintenance like print alignment or print nozzle.
Please let me know if you need more help.
Mar 03, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
I just purchased a new black ink cartridge for my dell 946 printer and properly installed it. When I went to print it said there was a full cartridge of ink but when the paper printed there was no ink on...
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Jan 05, 2011 | Dell 946 All-In-One InkJet Printer
I replaced my black ink cartridge and the printer will not print. I tried shaking the new cartridge. I purchased an Office Depot cartridge #TO529
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any ink-jet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
If after that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 12, 2010 | Dell Inkjet 720 Printer
Color stopped printing, changed cartridges, still will not print color. Now my black ink cartridge is acting up by starting off not completely printing text. What do I do now, buy a new printer?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
Dec 06, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
23 people viewed this question
old marine
old marine
