Question about Electrolux Lux 5500 Canister Vacuum
Electrolux 5500 The cord on my vacuum cleaner won't retrack. What is the trick to get the back end off the vacuum cleaner? It looks like it was pulled out too far.
  • 1,673 Answers
Depends on which model you have, but most of them you take off the center section, then you cab get to the 2 screws on top , and there is a screw on the bottom, then the back end will pull off. But I wouldn't try taking the cord reel apart, if that spring lets go while you are doing that, it could be dangerous. Also make sure that it isn't plugged in.
Posted on Jan 06, 2008
  • 75 Answers
Your local Aerus representative can fix that for you really cheap.... Especially compared to if it gets broke, that could be more to fix than if you bought a new machine.
Posted on Jan 14, 2008
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
Cord won't stay out, it keeps going back in
when pulling the cord out, it should 'keep' it that spot if you pull a certain direction, cant recall if it is up, or down, left or right, and pulling it opposite direction releases the cord again
Mar 10, 2013 | Electrolux EL6984A UltraSilencer Green...
I am trying to disassemble a electrolux 2100. I have looked at instructions given by Chemist 1961 and others. On the side, I have removed the rubber covers over the plastic rails but I can't remove the...
There's a tab at the back of the rail that needs to be released. Turn the vacuum on it's side, slip the tip of a standard screwdrive into the space between the rail and the back of the vacuum, and tap lightly with a hammer. Tap toward the front of the vacuum a few times until the rail is far enough forward to be slid out fairly easily. As a side note, the rubber covers do not need to be removed to do this.
May 08, 2011 | Electrolux Lux 5500 Canister Vacuum
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
Our housekeeper has twice pulled the cord out past the yellow marker and we've had it repaired both times at a cost of $75 ea. The housekeeper is now gone but I would like to try and fix the problem...
Try this. Set vacuum on it's back end. Gently pull out cord and release. It may take a few tries, but should work
Repair/service manuals are only available to authorized service tech at authorized Aerus Electrolux stores. These are in the form of software available only from AE to authorized stores. The explanation process would be quite lengthy, and would itself be worth more than $75.
Taking the vacuum and cordwinder apart is somewhat tricky and can result in damage to it. Reassembling correctly can also be tricky.
Nov 14, 2010 | Electrolux Lux 5500 Canister Vacuum
I have an electrolux 2100 and it won`t shut off when i depress the top button? thank you
You need to replace the switch button:
Take out the bag and keep the door open.
While the bag door is still open, turn the machine upside down so you are looking at the serial number.
Pull the cord out one foot.
Use a puddy knife and put it between the rubber side rails and the **** end of the machine.
Use a hammer or malett to hit the putty knife from the back of the rubber bumber toward the bag door.
Pull the rubber bumber stright out on both sides.
Once both bumpers are out pull the lower body of the canister from the **** end toward the intake of the machine.
Once the bottom is open you can then service the motor, cord winder, switch, and all other components.
For all the parts to fix the machine visit:
Mar 17, 2010 | Electrolux UltraLux 2000 Bagged Canister...
I have an epic 6500SR I'm trying to change the
You really don't want to get into the vacuum. You could cause more damage than what you have now. After you do get into the vac, the cordwinder is another monster to get into.
There are two strips,one on each side of the cleaner under the rubber bumpers. The strips have to be removed by pulling off the bumper and pull them out the front of the vac.This is not easy. After you get the locking strips out, turn the vac over and pull the bottom off. Then you can see the cordwinder.
The best thing to do is take the vac to a Aerus/Electrolux shop for repair.
Nov 02, 2009 | Electrolux Lux 5500 Canister Vacuum
Cord rewinder on a Electrolux model C102J vacum cleaner
Hi there Johnd, SmartAlec from here. I fix vacuums full time for a living and the first time i had this problem with the australian version of this vacuum it tok me an hour to pull it apart and back together. now i have done a dozen or so it is about a 30minute operation. I dont know what you rate your technical skill level at but i give this machine a 8/10 for hardness. It is most likely that the cord has jumped off the reel and is wedged so it shouldn't require parts but it cant be done without nearly stripping it down. There is no reset or similar for the reel. My advice unless your very confident take it to a repairer. It would be 1/2 - 1hr of labour charge only i would think.
Hope this helps.
Sep 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
How do you access and then repair the cord winder on an electrolux canister vacuum cleaner?
Is it the long type, 2 wheels on the back, one swivel wheel on front?
Aug 02, 2008 | Electrolux Vacuums
Hi , I have replaced the electric cord on Electrolux Lux Royal vacuum , but the rewind that retracts the cord does not pull it in . The coil spring looks ok but it will not pull the cord back in , any...
Generic problem for all Vacuums
Hi, I have replaced
Posted by dryder on May 02, 2008
Hi, I have replaced the electric cord on Electrolux Lux Royal vacuum, but the rewind that retracts the cord does not pull it in. The coil spring looks ok but it will not pull the cord back in, any suggestions please.
Thanks Dave Ryder
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The question I have is it the Electrolux or the Royal cordwinder, if the cordwinder is sprung you may have to get a new one or a good used one, it’s been a while since I have done a cordwinder and I have seen it done, but I know when you remove the cordwinder you need to lock in the spring so that it does not loose it tension and re-coil ability. You may want to ask your local vac dealer to see if you need to repair or replace. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134. Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Electrolux Lux 5500 Canister Vacuum Logo
359 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
