Question about Achiever CCS5000 Shredder
Need to find a supplier of spares for AT160 S
We have an Ativa desktop paper shredder AT160 S.
It stopped working so we contacted supplier, However, it was no longer under guarantee so we got a local company to have a look at it. He said that the relay control board was faulty. Where can we get spares from?
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
I have an Ativa 1850. When putting papers in to shred the papers move to the right side and bunches up the paper. The shredder now doesn't want to work properly. No papers will go through to be...
You probably need to get some shredder oil and lubricate the cutter heads. see: http://www.walmart.com/ip/Fellowes-Powershred-Shredder-Lubricant-Oil/8207323
Apr 19, 2011 | Office Depot Ativa 1850 (MicroCut)...
I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had overheated. The temperature light did not come on. I wait for over 30 minutes and tried using it again. I was able to shred a couple of sheets of paper and it stopped again. The next morning I couldn't get it to work at all. The green ready light is on but the shredder will not start. I can't tell if anything is stuck in it. How do I getting running?
Sep 08, 2010 | Fellowes DM8C Cross-Cut Shredder
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
Shredder won't turn on
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
Aug 24, 2008 | Office Depot Ativa DQ60M Shredder
Achiever CCS5000 Shredder Logo
35 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
