Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Kitchen aid wall oven kebs177dssp
After the self cleaning operation Oven will not heat up. Broiler nor baking working? Help
  • Anonymous Dec 27, 2007
    same problem (thermal fuse blew after self-cleaning cycle. Not able to heat oven. Control panel seems fine) - replaced the fuse 3 times.... now waiting for the 4th replacement. Conclusion: KitchenAid (whirlpool) does not see it as a problem &/or dont use the self-clean function.
  • Anonymous Feb 01, 2009
    This company will never get my money ever again. The self cleaning cycle should actually say SELF DESTRUCT cycle We even put in additional heat deffussion at the recommendation of an authorized repair service (NOT CHEAP) and that did not answer the problem. Clearly a defect in the design.
    President:
  • 1,314 Answers
Call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
Posted on Dec 29, 2007
  • robert samples Dec 30, 2007
    from site service bulletin 1 check to see if door opens beyond 90 degrees2 check for damage to door gasket3check the oven venting for obstruction,smoke eliminator,crushed separated or incorrectly assembled vent 4check blower fan for misalignment 5check for incorrect part#on fuse 6 the oven should not be in stalled in a corner if all these are ok change blower motor more air circulation the better if you get the idea
Why don't top oven broiler and bake elements heat?
we had that problem once. it turned out to be the control switch was broken
Apr 10, 2016 | Kenmore 27 in. Electric Self-Clean Double...
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
I have a Kitchen Aid Surpurba 1999 built in oven.
on the back of oven there is a hi limit thermal fuse /it is a one time fuse /eplace it cost about 23. to28 .00 . / you willhave to remove oven from wall ( two are best .. set it on a small table /cable may be short.. hope this helped /pls leave feed back ..
Dec 06, 2009 | Ovens
Oven won't heat
The only reason I know the answer to your question is because I am having the same problem. Our appliance quit working after we used the cleaning option. Both the bake and broiler quit at the same time. Our local repair man said that the problem is caused from a malfunctioning thermostat, which is about a $300 fix.
May 18, 2009 | Whirlpool RBS245PD Electric Single Oven
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
213 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
