Question about Daewoo Televison & Video
Remote OK button not working on daewoo tv
OK button of the remote control is not working on our daewoo television. daewoo television model is DSC3210EGB and the remote control model is R-40A01
nfandres
  • 168 Answers
SOURCE: Sony Vega Digital TV model KD-28DX50 U
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service technician
Posted on Jan 16, 2007
  • 3 Answers
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
Posted on Feb 12, 2008
  • 1694 Answers
SOURCE: TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Posted on Feb 29, 2008
  • 133 Answers
SOURCE: Tivo remote code for Daewoo Tv
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Daewoo TV is one of the following numbers: 0092, 0451, 0672, 1661, 1278.
If these numbers do not work, I would consider buying a newer universal remote. They can be bought at Walmart, for less than 10 dollars.
Hope these suggestions help you out. Please take a moment to rate the info that I have provided, by using the rating system below. Thanks.
Posted on Jul 12, 2008
SOURCE: old philips tv model no 21PT1532/05
this may be too late, but i had the same problem, then discovered that if you press the top of the volume up/down buttons together, the menu comes up. I was trying to solve another problem this way when I accidentally locked the TV. The instruction booklet tells me that you can only unlock it with the remote control, but that has long ago bit the dust. Does this mean that I'll never be able to turn it on again??!!
Posted on Jul 17, 2008
Need remote control
Buy one [RCA RCR312W] model remote control. Setup code for Daewoo TV with this remote control are: 10451, 10092, 10661, 10672
If you want more details and codes to other brand remote controls, check this link.
Dec 26, 2012 | Daewoo DTQ-13V5FC 13" TV
Dishnetwork remote control code for tv daewoo
Hello, Cheri Torres with DISH Network Customer Service here. We have a few different codes for each of our different models of remotes. The model number of your remote will be located on the back of the remote at the top, normally a two to three digit number with a decimal point. I will list here for you the best codes for each of our more popular models of remotes and the instructions for addressing the remote to the Daewoo TV. I hope this information helps and if you have any other questions please let me know!
Models of remotes Remotes codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 531, 719, 672, 664, 727, 524, 816.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 719, 531, 524, 526, 727, 529.
4.0 and 4.4 IR/UHF remotes - codes 719, 727, 733, 531, 524, 816.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 531, 719, 727, 573, 524.
20.0 IR and 21.0 IR/UHF remotes - codes 531, 528, 684, 524, 630,684.
Instructions for addressing the remote to the TV
1. Turn TV on.
2. Press and hold down the TV mode button until all other mode buttons light up red.
3. Enter the 3 digit code for your TV.
4. Press the pound(#) button once.
5. Test the functionality of the TV on the DISH remote.
Oct 24, 2011 | Daewoo DTQ-19V1FC 19" TV
Code for daewoo tv
hi,
You didn't mentioned any thing about the brand and model number of the remote you have. Need the same to give you code for Daewoo tv
ok
Aug 13, 2011 | Televison & Video
My tv remote quit working. I would like the code for Daewoo TV, model No. DTQ-13P2FC to enter in another remote.
For Time Warner Cable TV Remote Codes for DAEWOO-TV's - Go to Time Warner Cable web site to PROGRAM REMOTE -- Site URL is http://www.timewarnercable.com/en/residential-home/support/pyr.html Then select TW Cable remote model. Under Control a Device -- first select type of device (TV) Then select Brand Name (DAEWOO). TW Cable lists several codes to cover different models. Choose a code and input into remote to see which code works. Try all codes. There were several codes to choose from and to try inputting into my TW Cable remote. Finally, the next to last code worked on my TW Cable remote -The Atlas OCAP 5-Device Remote Control by Universal Electronics. The code for this remote for Daewoo TV Model DTQ-13P2FC is 1661. Hope this helps. Otherwise, try checking the site of your cable or satellite provider & you should be able to get their add device codes for free.
Jun 21, 2011 | Daewoo DTQ-13P2FC 13" TV
I am having problems getting my Daewoo TV to work with my dish network remote.
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to addressing your DISH remote to your Daewoo TV. We have a few different remote codes for each of our different models of remotes. The model number of your remote will be located on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes as well as the instructions for addressing the remote to your TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com.
Codes for Daewoo TVs
3.0, 3.1, 3.2, 3.4 IR remotes - 531, 719, 664, 727, 524 and 816
5.0, 5.2, 5.3, 5.4 IR remotes - 719, 531, 727, 526, 529, 530, 531, 684 and 658
4.0 and 4.4 IR/UHF remotes - 719, 727, 733, 531 and 524
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 531, 719, 727, 573, 652, 524 and 505
20.0 IR and 21.0 IR/UHF remotes - 531, 528, 832, 524 and 630
Instructions for addressing the remote to the TV.
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
How can i get the installation menu off my tv without the original remote i have tried a universal with no success
Hello
Please give me the model number of your Daewoo TV. Without it, how can I send you a solution to your problem, whether it in case of TV or with remote control handset. Give me details please. OK.
Dec 28, 2010 | Daewoo Televison & Video
Cant find code sheet need code for a deawoo tv for remote sru3006wm/17
Code Search Results--> --> Code For Model RCU300T
Code 004 for Daewoo TV Code 005 for Daewoo TV Code 006 for Daewoo TV Code 016 for Daewoo TV Code 017 for Daewoo TV Code 082 for Daewoo TV Code 171 for Daewoo TV Code 190 for Daewoo TV This is a basic set of codes for the TV, I am not sure of the model on the remote so I can only give you what I have. If these won't work, add a 1 in front of these 3 digit codes to make a 4 digit code, this should work. Good luck
Nov 15, 2010 | Universal Remote Control 6-Device...
Service mode code
How to enter the service mode using the user remote control.
Turn the set on.
Direct the remote control to the reception window of TV.
Push buttons of remote control in sequence as follows.
→MUTE
→DISPLAY
→MUTE
Here you also get a service manual for a similar model.
Jan 06, 2009 | Daewoo Televison & Video
Codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Dec 13, 2008 | GE JASRM24912 Remote Control
Daewoo Universal Codes for Comcast Remote
For Daewoo TV Model DTQ-27U4SC, try this for Comcast Universal Remote (one with the red select button):
1. Press TV button
2. Press Setup button until TV button blinks twice
3. Enter 10451
4. Press Power button (TV should turn off and is set)
Mar 01, 2008 | Daewoo DTQ-1440FC 13" TV
Televison & Video Logo
46 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
