Question about Microwave Ovens
I would like to find an electrical schematic for a model JES1036PWH03 GE microwave oven. Oven is dead, no power to control panel or light. Power thru fuse is good.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    There is usually a tech sheet with schematic located inside the microwave oven behind the control panel. Have you checked there?
Couldn't get a schematic from GE. CSR told me they consider the unit a throwaway if it fails. Only parts they stock are the glass turntable and the roller ring. I ended up probing and metering the 110v power circuit. I found an open thermal cutout that was preventing power to the control panel. I removed it and took it to a local parts store and matched it up with a generic cutout with the same specs. Installed new unit and the oven is working like new. Cost: $15.00.
Posted on Oct 06, 2009
The control panel of microwave dead. No lights on the panel. There is power to the outlet
If it worked after unplugging and reinserting, it is possible that there is a wiring problem with the plug and wiggling the wires "re-made" a connection. Try plugging in to another outlet to eliminate a dodgy outlet problem.
Mar 26, 2015 | GE Microwave Ovens
No power. unit dead.
may popped the breaker would have to remove grille and control panel to confirm. unplug microwave first
Nov 05, 2013 | GE JVM1630 Microwave Oven
GE JVM1540sn1ss Microwave loses all power including interior light, control panel, etc. I have to set the clock each time. I can wiggle door or control panel and power comes back on. I appears there...
It may be a loose fuse holder or a rare condition, an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If you need further help feel free to contact me with your full model number and symptoms.
Jul 06, 2011 | General Electric Microwave Oven
Ge Over The Range Microwave Oven JVM2050...5 yrs. digital clock working so there's power. inside light out and basically digital key pad seems dead.. we had a few flickers of light and a brief turn of...
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 18, 2010 | GE JVM2050 Microwave Oven
Have a GE model JVm1650bh05 Microwave. I put in
Check the fuse in the bottom of the oven ... near where the power cord enters.
Oct 19, 2009 | GE JVM1630 Microwave Oven
Control Panel "clock Buttom" dead
Sounds like your keypad has failed, and on some models it's not available separately, so you have to buy the entire control panel assembly.
You have to remove the controller (see the video here) then unplug the keypad strip (see photo below) then move your circuit board to the new control panel assembly (part #
WB07X10798 if that's the right one for your model).
See exploded views
here. You can find this part for $101.91 here (compared to $163.50 from G.E.!).
Jul 20, 2009 | GE JVM1650 1000 Watts Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1630BJ Microwave went completely dead with no power
Sounds like the bulb shorted, which is very common, and the first time it blew the fuse.
It sounds like when you put the new fuse in and tried it again, the bulb was still shorted, and this time it damaged the board.
We see (and repair) thisa lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about aweek.
Atour Web site, we have a videoavailable showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure oftenoccurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often alsoaffect the exhaust fan operation, too. The lights and fan can beinoperable or stuck on too.
Details of our serviceand critical safety information and disassembly information is at oursite, and our link is at ourlisting hereon FixYa.
Feel free to contact me directly (and please remind me of yourfull model number) for more information & help.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
William E. Miller
prototech@usa.net
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
150 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
