Question about Electrical Supplies
It feels hot, stays up for 10 min and flips. never had any problem for past 5 years. it just started today morning
  • 8,404 Answers
Where is this breaker and what gets power through it???
Is it 110 V 15 or 20 amp?
Calculate the load.
As devices age, they frequently start demanding a little more juce to run. If your load is near the rating of the circuit, you should consider redistributing the load to other circuits if possible.
I hope this helps you
a
Posted on Oct 06, 2009
Parked my Truck the next morning it was dead , what could be draining my batteries
Could be anything in the truck. The best way to narrow this type of problem down is to due a parasitic draw test. This is done by disconnecting the ground from the battery. Then connect an amp probe inline between the battery and terminal. Watch the amperage on the meter, it should drop to 5 ma or less after 10 min. This is sleep mode. If this happens you either don't have a draw (drain) or you have a draw that is that can't be duplicated at this time. If your amp draw is still over 5 ma after ten min. Something is staying on. To find out what that might be. Without opening any doors or actuating any switches, start removing and replacing fuses while watching amp draw on the meter when you see the amp draw drop you have found the circuit that is draining the battery. Hope this helps.
Oct 02, 2016 | Cars & Trucks
What is defrost overheat?
There is defrost heater which comes on in defrost cycle. defrost heater stays on certain time(lets say 15 min), but lets think it came on to defrost and melted all ice of the coils during 5 min, but we still have 10 more min design for heater to stay on. if heater will stay another 10 min it will warm up your stuff in the freezer, so everything will start to melt. to get around this, all freezers have limit thermostat(defrost thermostat), when that thermostat feels heat from heater, it will shut power off to the heater, so it still in defrost cycle, but heater will be off for another 10 min. When that thermostat get stuck in closed position(does not shut power to the heater when all ice melted out), you will have defrost overheat. so most likely that defrost thermostat needs to be replaced. here is the video how i replaced it on subzero pro series.
Apr 07, 2014 | Sub-Zero 650/SRH Stainless Steel
1989 mercedes 560 sel, gas, w126/ Car cold starts every morning and idles for 10 min. then stalls
the idle control motor probly worn-on the throttlbody--also the tps sensor - get intake area inspectd--a haynes manual will xplain complete car-partstore hazit--------starter fluid is used for low compression or weak spark
Dec 25, 2013 | Cars & Trucks
I want the light to stay on for only 1 minute
I just had my new opener today. try this:
1. press & hold the LOCK button until the lights blinks.
2. if it is a single blink, the timer is 1.5 min.
3. if you repeat step 1, blink twice means 2.5 min.
4. if you repeat step 1......., 3.5 min
5. if you repeat step 1......., max is 4.5 min
May 24, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have an Acer Aspire 9500 and lately it has started to turn off after about 30 min. Any idea what might be the problem?
Most likely, either bad fan(s) or a bad power supply and low battery.
Does the bottom get really hot? After 10 minutes, do you feel hot air blowing out of it anywhere? Do you hear a whizzing fan sound? You may be able to simply blow the dust out, do NOT use canned air, just blow in puffs like you were trying to blow out a match. You may need new fans.
Let it stay turned off but plugged in overnight. Does it last longer
than 30 minutes in the morning? That could indicate a weak power supply that the battery is making up for...till the battery runs out.
Sep 08, 2010 | Computers & Internet
The engine does not start on hot weather. it start in the morning and evening but bot not in the afternoon. I've been to different places but nobody knows why
Engine main relay. Were talking crank no start correct!
If you were to start car coldlet it run for 10 min. then restart say in 5 min anytime of day will it restart. If answer is no then its the main relay. Contact on the relay are worn and seperate when they are hot.
Apr 19, 2010 | 2003 Honda Odyssey
Just had thermostat replaced. After 5 days of use:
You may have air trapped in the system. Take it back where they changed the thermostat and have them bleed the system. If you want to DIY post back.
Jan 18, 2010 | 2005 Chevrolet Equinox
Electrical Supplies Logo
52 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
