Question about Brother MFC-9420CN All-In-One Laser Printer
Missing print There is a line of missing toner running down the side off anything that I print. THe line runs from top to bottom and is about one and one half inches from the edge? Is some thing stuck there?
  • 4 Answers
It sounds like there may be a speck of dust or similar on the laser slit glass. Pull out your OPC cartridge (the big green belt, be careful not to touch or damage it, and keep it out of the light as much as possible-lean it against the wall in a cupboard or under your desk), and pull out all 4 toner cartridges. Get a clean cloth and carefully wipe out any toner spills or other dust at the bottom of the area the OPC sits in. Maybe even blow gently through a straw to get toner out of tight corners. Make sure the narrow strip of glass that goes across the printer base under the OPC area is clean. Refit all parts and try again.
VitalStatistic63
Posted on Feb 11, 2008
Missing print
machine needs drum and developer, but a temporary fix would be...open front door near notice green handle where toner is replaced, look to the right of green handle and down about 2 or 3 inches, you should see a plastic or chrome cover the size of a postage stamp, remove the cover and you should see a 3/4 inch wide piece of glass barely sticking out, carefully grasp the glass and pull it out of machine, wipe the toner off the glass , put glass back in and replace cover , shut front cover and run copies .
Jan 30, 2014 | Ricoh Aficio 2015 Copier
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
What's wrong if my test page prints fine, but anything I print off the net has several letters missing on the right side of every line?
your toner cartridge is running low or fuser film is damaged or maybe laser sanner mirrors are dirty.
Usualy toner cartridge is the problem. Try to replace it whit new one firstable.
Jan 11, 2011 | HP LaserJet 4300n Printer
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
White lines and "missing ink" on printing text & graphics
you have a defective or near empty toner cartridge. Try shaking it side to side
Jun 11, 2009 | HP LaserJet 1100 Printer
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
114 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
